It could be a board issue, if not as simple as a bad wire at the row connector. Manually test directly at the CPU switch connectors with the following procedure. This will identify if there is a wiring/playfield problem or CPU problem.
Testing the Switch Rows (all WPC revisions).
To test the switch rows, do the following:
Remove the backglass and fold down the display to gain access to the CPU board.
Turn the game on.
After the game boots, press the "Begin Test" button in the front door. Go to the Test menu's "Switch Levels" test.
Unplug the connectors at J212, J206, J207, J208 and J209 (lower portion of the CPU board).
Connect an alligator test lead to pin 1 of J207. Pin 1 is the right most pin, as facing the board.
On the other end of the alligator test lead, clip on a 1N4004 diode, with the non-banded end away from the alligator lead. Touch the non-banded end of the diode to pin 1 of J209. Again, pin 1 is the right most pin, as facing the board.
The display should show switch 11 is closed.
Move the diode/alligator lead on J209 to the next pin. The display should show switch 12 is closed.
Repeat the previous step, until pin 9 of J209. Switches 11 through 18 should be closed on the display as moving forward, pin by pin, on connector J209.
If a particular row does not display as closed, or is closed without any test lead connection, replace its corresponding LM339 chip on the CPU board. Here are the switch rows and which LM339 controls them:
Rows 1,2,3,4 = U18
Rows 5,6,7,8 = U19
http://techniek.flipperwinkel.nl/wpc/index2.htm#switch
