Switch doesn't work during gameplay or in test mode. I first noticed because I can't advance the captive ball reward. On another note, I have since realized that the gate in the top loop does not open. I don't know if the captive ball advance requires both the left and right top loop switches or if just the top right switch advances?
I did solder a new diode on the switch, and have tried two new switches (same new diode on both switches as I only bought 1)
I have not noticed any other switches that are not working.
As for actuator adjustment, I have removed the switch from the playfield and depressed it completely.
Will check wires for breaks, and any other advice or thoughts are appreciated. I don't yet understand the switch matrix and how all of these things work together yet, so I'm at a big troubleshooting disadvantage
Thanks again,
Aaron
