New! Dark mode!
(Topic ID: 275975)
Fish Tales motor voltage
By Diver12
56 days ago
  • 9 posts
  • 4 Pinsiders participating
  • Latest reply 48 days ago by Pin_Guy
#1 56 days ago
Got a Fish Tales little while ago and the reel was not working. Saw there was no rubber for the pulley and ordered one from Marco’s. Attached it and nothing. I did the reel test and the motor does not move at all (took off of gearbox to confirm) I am getting 0.6v at the motor.
Trying to find out what the correct voltage is for the motor to find out if this is a board or a motor issue
#2 55 days ago
Use a 9v battery to test motor. Probably not the motor.
#3 55 days ago
Ok
Works with a 9v battery
Checked the small board that runs to. The resistors showed being complete. Don’t know what the two brass things are on it.
Re-seated pins and no change
What would be my next thing to check?
#4 55 days ago
Quoted from Diver12:
Measure this voltage from the red wire to ground, you should have 12V. If you don't have 12V there, follow it back through the circuit until you find where you have it.
If you are lazy like me, just connect the black wire on the motor to ground and see if it turns. If it does, its a control issue.
#5 54 days ago
I connected the black wire to ground and it did not work. What is the next step?
#6 53 days ago
Did you check that you have +12 VDC at the connectors on the yellow-marked circuit that Pin_Guy attached?
#7 53 days ago
What classe said
Follow that highlighted line back from the motor to J118-2 to find where the voltage is lost and fix it.
Black wire to the ground braid and stick the red lead into the back of connectors starting with the motor and working back to the power driver board.
You would actually have massive issues if the 12V was missing at the power driver board, the most likely break points are going to be the 2 connections to the EMI board or the connection at the opto switch board...I'm assuming that J1-2 on that board has two wires, one to power the board, and a second to power the motor.
#8 49 days ago
So I am getting 5-6 volts at J1 and J2. Always want to mention that I am getting errors for Reel Opto 1 and 2.
When I put the red lead on the driver board in several places it reset the machine. Couldn't get any good readings
#9 48 days ago
Quoted from Pin_Guy:
Did you inspect this point for loose wires?
I don't know what you have for a meter, but if I had a meter that did that I would throw it away.
$ 19.99
PinballElectronics.com
$ 16.50
