For the Life of me cannot get the Fish Tales knocker to work! Tried a new one since mine had been removed completely and wires bundled with topper wires. Cut the diode off as I have learned from Pinside posts. Screwed it in, got proper 3 wire connector, only using 2 holes leaving middle blank, copied my Addams and Gilligan. Checked wires, and data line... blew fuse F-5. Replaced fuse on power board( It's a new rottendog, how new I don't know, came with pin) Tried again, Fuse blew, reversed wires on knocker, even though I know this doesn't matter with diode gone. Now at power up , knocker engages once just locking in knock position touching upper cabinet plate, was afraid and turned game off after about 5 seconds, noticing that cpu had not gone to blinking center light, perhaps not enough time. Did not want to damage the rottendog driver board, since I think it's new. I know Q-70 on driver board is the knocker and reads about 7ohms, diode under it also appears good at 6ohms. Not sure if it's the cpu, or driver board. I've unplugged it to find solution. Any Ideas Pinsiders?
