(Topic ID: 305904)
Fish Tales Help
By yort
2 years ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 2 years ago by GPS
    #1 2 years ago
    While doing my yearly battery change I had the back box open, and when I powered up, a resistor blew (caught fire for a second or 2). I’ve tried googling the resistor with no luck. Can someone tell me where I may be able to buy these? Another question I have, is this something that just happens over time or should I be looking for a cause? Any help appreciated.
    troy
    F34647C1-58E2-49F6-AEAD-487745A0A853 (resized).jpegF34647C1-58E2-49F6-AEAD-487745A0A853 (resized).jpeg
    #2 2 years ago
    Ok so found an old post stating these 1uf axial tantalum capacitors originally rated at 35 volts should be replaced with 50v. I found some at a store called mouser electronics. There are several ones to choose from and I'm not sure what I need exactly. This is the link to the products I'm seeing.
    https://www.mouser.ca/c/passive-components/capacitors/tantalum-capacitors/?capacitance=1%20uF&m=KEMET&termination%20style=Axial&voltage%20rating%20dc=50%20VDC
    Can someone point me to the correct replacement? Thanks
    Troy
    #3 2 years ago
    Common problem. Those tantalum caps burn up spectacularly after a while.
    I've replaced them with the same uF value electrolytic cap successfully, easier to find.
    #5 2 years ago
    Troy
    Maybe what is throwing you is the percentage value at the end of the specs. Believe this to be just a tolerance similar to a silver or gold band on a resistor. I would opt for as small a tolernwxe as possible. Just match the capacitance and go up to 50 volts on rhe voltage and you’ll be all set
    Hope this helps
    G
    #6 2 years ago
    Thanks for the help guys, ya GPS it was the percentage values that had me second guessing.
    #7 2 years ago
    This page was printed from https://pinside.com/pinball/forum/topic/fish-tales-help-3 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
