Hi Fellas,
Quick question on the fly casting reel which holds the balls sent to it by casters club.
When there is a ball in the reel that has not been taken advantage of by the end of the game, the reel will rotate to try and get it out. Sometimes this is successful and sometimes not. If not, then when you push the start button to begin a new game, the game will try and again get that ball out which again, will sometimes be successful the first time and sometimes not which would require a second push of the start button to try and get the ball out. At this point, the ball is usually evacuated and a new game can be started.
Is this indicative of an issue with the game (which I suspect, Opto??) or does this just happen and it is a part of livin with the game so to speak. The reel spins so fast that it seems like this speed may actually help keep the ball locked in and not allow it to fall out of the backside of the reel.
Any thoughts here guys would be most appreciated. Thank you as always.
George
