Quoted from tonyhoff1:Probably a blown 2803 chip if the switch matrix is not working correctly. Was there acid damage on the cpu? If so check the connectors and look for corrosion.
There is minor battery corrosion in this area, I did clean it up and check the traces in the area as well and it seems good.
Quoted from PinballManiac40:I am thinking the same thing. With power off, you can test the resistance of U20 pin 9 to 10. Normally this is about 1 Meg ohms. Usually, I see this under 200 ohms when this message appears and the fuses are not blown. When it is 10 ohms, normally it blows out F115 , I believe.
Im probably not doing this correctly, but I have my meter set to 2000 ohms and with the power off, I check across pin 9 and 10 (the last two opposite pins on the other end of the notch in the IC) and I get a reading of 1650.
When I turned on the game today, still a very long boot up (30 seconds easy) but I didnt get the error message but the problem still exists. So Im thinking the U20 chip as well. Error message came back after power cycling while checking stuff
I still have power issues (I think). I have one of those WPC reset fix boards with the led's on them. So for the hell of it I plugged this in (J210) just to see what it did. The LED's are all on, here is what the led's indicate: Blue, Red, + Green Flashing = 5V went both high and low PLUS 12V went below 9V.
Here are my readings:
TP1 = 14.60
TP2 = 4.87
TP3 = 11.88
TP4 = 0.3?
TP5 = Ground
TP6 = 70.2
TP7 = 21.4
TP8 = 15.8
All Led's on the board are on and led 3 is blinking/flashing.
