I bought a CPR Fish Tales a while back and going to start my restoration sometime this winter.
It's a Bronze and only issue it has it's warped about 3/4". With the rails on, it's about 1/4". Once populated it's going to lay flat. Nice score.
These Fish Tales are notable for having some ripple in the clear and inserts lower than the playfield as the wood continued expending. Call it whatever you like.
Also got the mini-playfield with minor black paint missing on the edge and i'm going to address that as well.
Now I had this playfield for more than a year. I'm going to sand flat and shoot them again with SprayMax 2K. I got to do it before winter times hit Canada, which could be tomorrow...
My Pinbot playfield restoration gave me the confidence to tackle this and take a step back with a "perfectly" good playfield
You can see how the insert sits lower and also how there is sanding swirl marks in the current clear.
I handsanded with green pad the holes and scoop. I'm going to try a different technique this time and machine sand using a random orbital sander using 800 grit dry. If I'm not happy with the process, will go back with wet block sand.
Mini was block wet sanded as it is very small and insert were flatter than on the main playfield.
