Quoted from Paseb:Hey guys
Just got back my FT a couple days ago from a full resto.
I have an hard time keeping the ball in caster club for ball lock. Quite often, i shoot it and it goes back.
Could it be that my game is too inclined and the ball goes in too quickly? Game is super fast.
Also, while playing, the sound will completely shut down. I can still play but no sounds.
I then have to restart the machine and sound is back. I reset chips and ribbon cables. Any thought?
Thx
Does the caster club have that metal "W" shaped wire preventing the ball from kicking out of the casters club? If it's missing then it's needed . If it's there, it needs adjusting so that after the ball bounces off the back of the casters club, the wire forces the ball to fall back in the vuk.
The drop target will only block the entrance when you've locked 2 balls for a double jackpot, making sure you won't lock the 3rd one. And then once you've collected the jackpot, it will close then and force you to hit it once (if difficulty is set to normal) or twice (if set to hard) before it drops down and allows you to lock more balls.
So, if it doesn't stay in the casters club it's most likely the W shaped wire. Before I restored my machine I had a lot of balls kicking out. Ever since I adjusted the wire just right I've never had an issue (well over a year now). In my case there was a hack that had been done adding a "L" bracket to stop the ball.. I patched and sanded all that nonsense, fixed the wire and it working top notch. I don't think the speed of your table has to do with it because I tested by hand, rolling the ball in the casters club much faster than the flipper could.
