I really need some help with the Caster's Club switch. I can't consistently set the switch gap to properly detect the ball is sitting in the Caster's club. Half the time it works, and the other half of the time, I have to wait for the ball search.
Is this switch supposed to be normally open or normally closed (without the ball in there)? Is the fork part of the switch supposed to be on the top or bottom of the plunger? Is the configuration in the photos correct?
The switch works perfectly well in the test menu.
I recently installed a new coil sleeve in the coil, installed a new fork switch, and installed a new dowel.
