Redrew the lure and scaled everything to the correct ( pretty close) dimensions. I was lucky the old switch covers base was still attached to the switch. I guess at some point it broke on the previous owner and he had to use the broken base ( its threaded) to be able to attach the switch to the habitrail. Made things easier to scale since I could reference that broken part.
The first piece is the laminated decal I printed. Piece 2 is the template I'll use to cut and bend the metal (drawn in AutoCAD). And the last piece is what the part will look like when bent. Ill post a picture once the switch is installed Thanks again !
