Sorry to see the glass like that... but pics like that almost demand a story
Quoted from rufessor:Sorry to see the glass like that... but pics like that almost demand a story
*sigh* Alright. So while this was being stored, I had in the old glass in it, the glass from the fire. When I went to remove it, it was being very stubborn. I got it half way off and got just a bit too rough and boom. It was a hell of a sound
Quoted from futurepinhead:One step forward, two steps back
Oh, dude...I hope you'll forgive me for the hysterical, guffawing laughter I just let out when I saw your caption and pictures. I hate to say it, man, but that may be the most expensive $25 pin I've ever seen.
Sorry, but oh, my word...that is *FUNNY*!!!!!!
Quoted from boagman:I hate to say it, man, but that may be the most expensive $25 pin I've ever seen
Hahaha you ain't lying. This was the original bad glass anyways. I remember putting it on there "incase something happens". Turns out I was right.
Oh well, was being replaced anyways.
Installing some new speakers. I have to be ready for board day. I got ROMs in today from John Wart. If you ever need ROMs, please consider John. He also helped me find the boards for an unbelievable cheap price, $525 actually. Talk about a stand up guy.
Boards are in. I have to go pick them up about 20 minutes away. I will be picking them up after work. I'll need to run the wires and install boards and roms tonight. The tricky part is going to be getting the connections in their appropriate spot. Remember most of the wires are brown or black at this point. Hopefully the keys will help me out with the connections. A very helpful pinhead on a Facebook group took the time to send me dozens of photos this week. She is amazing. Thanks Christy if you are on here as well!
EDIT: I probably won't be ready to hit the switch tonight but it'll be in the next two to three days for sure as long as everything arrived as it is supposed to.
You didn't wash the harness?
At least get some rags and alcohol (maybe some Mean Green too) to wipe off the soot on the wires so you can see the wire color.
Quoted from KenLayton:You didn't wash the harness?
Put the harness in the dish washer. I did that with my Pinbot, worked like a charm. Vid suggested it, so I won't take credit for that idea.
Yeah I did, they were pretty bad. I'll post some pictures in just a second. I washed them first with mean green and then They soaked in a bath of Alcohol for a day. They got a little better but still not good at all.
Quoted from thedefog:Put the harness in the dish washer. I did that with my Pinbot, worked like a charm. Vid suggested it, so I won't take credit for that idea.
I would have to unsolder from the board. For some reason, this pin the wires go from the board connections all the way to soldered on the playfield parts. There is no connections, I've never seen that in a pin. That's not out of the question to try but it won't be until I know I can make this thing run again. Even then, I doubt that would do any better than Mean Green and alcohol.
For the metal backbox mount (is there a name for this piece?) it is rusted to hell. I am just trying to make sure I can get the game running before I pull this piece and restore it. So what I am doing for testing is sanding down the mounts to achieve a solid ground. I de-rusted the screws that hold the boards in and they are drying now. Once I verify everything works, I will pull the mount out and will probably have to paint everything but the mounts. It is extremely pitted due to extensive rust.
boards look good. But those connectors are probably all gummed up with smoke residue. Things might not work right until you repin every single connector. Going to be a big job. Not expensive but very time consuming.
Quoted from CaptainNeo:boards look good. But those connectors are probably all gummed up with smoke residue. Things might not work right until you repin every single connector. Going to be a big job. Not expensive but very time consuming.
I guarantee this is going to be the case as well. I'm not looking forward to it but I realize it needs to be done. Boards do look good though, I hope the DMD didn't get damaged in the move and I hope the MONOPOLY burn in is not too severe when it's being played.
Quoted from rufessor:Ha!
THE SUSPENSE IS KILLING ME!
Wake up and plug this sucker in - now!
Oh shush
Getting closer...
I lost the light harness for the strip tease toy, so I'll have to make my own when it comes time.
Here's my prediction.
40% chance fuse will blow
30% chance it'll work
20% chance it'll do nothing
10% chance it'll catch on fire again
20% it is.
Lights came on some sound indication comes through, (what does this mean)?
Nothing on DMD. When I first started turning it on, the leds on the driver board, half were on. Now they are all on. The sound didn't come on for like 30 seconds when turned on, now its immediately.
This is the sound.
Well, first step in the right direction.
Hopefully this weekend I'll be able to start redoing the connections. I have the wire harness from the parted out redemption. They have the same connections and even keyed perfectly. I should be able to remove the old wires from those, nip the new wires and plug them in correctly.
I don't know anything about Sterns so bare with me. Is there a switch that is putting it into the menu? Is it going into menu since this is the first time its being booted?
It sounds like it's immediately going into diagnostics. Likely shorted diagnostics switch or wiring.
Your dead display will likely be ribbon cables to/from the DMD driver board. Ensure both ribbon cables are red stripe to pin one on both sides. It seems like the game is booting. You wouldn't get that sound if it wasn't.
Rob Anthony
Pinball Classics
http://LockWhenLit.com
Quality Board Work - In Home Service
borygard at gmail dot com
Thanks Rob. I was curious on the switches at the coin door so I disconnected them near the door. That didn't change it. So that means it's in the backbox more than likely. This was the same sound it was making with the old boards so I know its not the new boards. I will have to trace them up this weekend. More than likely they got melted together.
I got the DMD going, let's just say someone working on this game is an idiot
i don't know if the wiring harness from something else will work. Might have some of the same connectors, but they will be all different lengths and go to totally different areas of the playfield. Plus you won't have high power going where you need it, thicker GI wires where want and need them. That would just be a shit mess. I'd stick with this one and just put new molex connectors on everything.
you could just send the harness out. I'm sure someone here would redo all the connectors for you for a charge.
Disconnect CN6 from the driver board. That may get you into attract mode. Follow those wires back into the cabinet to find the short if so.
Rob Anthony
Pinball Classics
Quoted from CaptainNeo:i don't know if the wiring harness from something else will work. Might have some of the same connectors, but they will be all different lengths and go to totally different areas of the playfield. Plus you won't have high power going where you need it, thicker GI wires where want and need them. That would just be a shit mess. I'd stick with this one and just put new molex connectors on everything.
I was talking about just replacing the connectors, not the whole harness. I have all the ones I need since the redemption game used the same boards and the connections are already keyed the same. Not sure if you can reuse these connections.
Quoted from CaptainNeo:you could just send the harness out. I'm sure someone here would redo all the connectors for you for a charge.
I'm actually pretty good at crimping, I have had a lot of experience on Sys 6 games in the area. I think I might go that route, its the safest way really. I haven't decided.
Quoted from Borygard:Disconnect CN6 from the driver board. That may get you into attract mode. Follow those wires back into the cabinet to find the short if so.
Rob Anthony
Pinball Classics
Centerfold closed correctly. Strip tease motor is running continuously. The pyramid spinny thing is not spinning to its correct spot, but I'm pumped!
I would not try and use those pressure type connectors. They are garbage. Use the trifucate pins and make new molex style connectors.
Quoted from CaptainNeo:I would not try and use those pressure type connectors. They are garbage. Use the trifucate pins and make new molex style connectors.
I'm building a list of connections right now. There's no point in going all out this far to cheap out now. It looks like I'll be around $35 before shipping on all the connections. It will be a very long process. I'll probably try to do 3 or 4 a day so I don't burn myself out.
Awesome news!!!! Yes!
Congrats- might as well get gold plated- they will never corode and your never going to sell this game after all this.
Small update. I actually got pretty good at wiggling CN6 and being able to move my way through the menu. Wiggle left for select, wiggle to the right to navigate left, etc. So I got to the centerfold motor test and it turns out that's the one getting stuck running. The Closed switch isn't activating so really I'm at a stand still until I can rebuild the connections. That's going to be almost all of my problems.
Thanks guys, GPE was out of town and their site was down last week (I'm assuming for the expo) so I will get around to purchasing these connectors sometime this week.
Just bought all the connectors. It was around $32 shipped. Over 250 parts in the order and I forgot the damn keys...
Email sent, still waiting to hear from them. Hopefully we can get that added with no issues, I can do it without them but I would much rather not. If I was a full on operator I would just break toothpicks in them
Ok, I got the keys added to the order. They were very quick to respond to me, I love dealing with GPE. I have a couple switches coming from Marco that snapped off while I was cleaning them. That should tell you how brittle some of this stuff is to deal with. I am sure I will end up replacing at least a quarter of the switches after a little gameplay.
Quoted from futurepinhead:Ok, I got the keys added to the order. They were very quick to respond to me, I love dealing with GPE. I have a couple switches coming from Marco that snapped off while I was cleaning them. That should tell you how brittle some of this stuff is to deal with. I am sure I will end up replacing at least a quarter of the switches after a little gameplay.
I sincerely hope that I get to play this machine one day. It's kind of a semi-obsession with me, quite frankly. I'm always checking for updates, which you've been very kind about posting, thank you.
I shudder to think what this thing will end up costing you in the end.
Quoted from boagman:I sincerely hope that I get to play this machine one day. It's kind of a semi-obsession with me, quite frankly. I'm always checking for updates, which you've been very kind about posting, thank you.
Thanks, I like hearing that. It has been a very long tiring process. I doubt I will take anything like this on for a few years after this one. If I came across another, I will do some steps to prevent further rusting and I would store it for a bit.
Quoted from boagman:I shudder to think what this thing will end up costing you in the end.
I quit adding it up for the exact same reason.
the used stuff you buy should have the same value if you end up parting it out. It's a great journey to follow and think about all you are learning.
-c
Enjoy learning all the cool stuff and when your done, you will have an awesome mechanical beast that will keep you and your friends entertained for a very long time- although a beer or two never hurts
I have two games ripped apart currently with pieces spread all over the place- and yet slowly, slowly, a pinball machine appears from the dust. This is fun stuff.
This page was printed from https://pinside.com/pinball/forum/topic/first-stern-a-smoking-hot-2002-playboy-extensive-smoke-damage/page/8 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
