New! Dark mode!
(Topic ID: 177934)
First Playfield resto..complete non-artsy noob......Finished!
By Sonora70
  • 64 posts
  • 20 Pinsiders participating
  • Latest reply 2 years ago by Pinslot
  • Topic is favorited by 33 Pinsiders
There have been 23 images uploaded to this topic. (View topic image gallery).
There are 64 posts in this topic. You are on page 1 of 2.
#1 3 years ago
This is way out of my character, however the weather is terrible (hate winter)and I'm willing to step out of my comfort zone a bit. I bought this Flip a Card back during the summer that had been stored in building for a long time. At $200 I may have paid a bit too much for it but the backglass is in really good condition plus I've heard it's a good pin to have and I thought I could always enjoy another wedge head in the collection. My initial goal was to clean it up and play it. After making a few passes with the ME and alcohol the finish playfield isn't turning out as good as I thought it might. So.....I think I'm willing to try my first restore. I am not artsy.....no where close.
Equipment I have on hand:
Harbor freight air brush
Harbor freight pancake air compressor with cleaner/moisture separator attached
Frisket paper
exacto knife
Createx paints
water slide decal paper
my teenage daughter to help me mix colors
I've read Vid's guide but I'm hoping I can still get a couple questions answered before I begin so that I don't create more work for myself, plus....I would like to end up with a nice looking playfield.
Questions:
After stripping and cleaning the entire playfield, do I then clear coat the entire playfield before I begin any painting at all?
Second, I'm really nervous about the small print areas such as the "10 points" with the arrow and the "Gottlieb and Co. logo. Vid's guide says to scan these type areas but this part of the process is really confusing to me. Can someone break it down a bit for me?
Any pointers that I would need before I begin?
Thanks for your help, I hope to post progress as well as complete this restore.
#2 3 years ago
#3 3 years ago
Yes clear first after getting it as clean as it's going to get.
The idea for the small text is to scan it, remove the background in photoshop and just print the black text and arrow to lay over the aqua. How exactly to do that in photoshop can be a little involved.
Your hardest obstacle might be the "50 points" text in the inlanes because it's white on color, and you can't print white text on a decal.
So you can go to different lengths depending on how pristine you want it to look. Personally I would go for a "player's" look, just hitting the eyesores. Fix the aqua, touch up black print and keylines, repaint white under the plastics. That'll make it look pretty good, and with a fresh clearcoat and fast play I'll be great. YMMV!
#4 3 years ago
You could look for a custom decal provider -- typically these are for scale modellers -- like here: http://www.bedlamcreations.com/waterslidedecals/rfq/index.htm
They use an ALPS printer that can print white ink.
Another alternative is to cut a paint mask with the Silhouette Cameo cutter or similar.
You will need a scanner like the HP Scanjet 4600 or 4670 (from ebay if one shows up) or the Doxie Flip.
#5 3 years ago
Thanks for the tips. I'm assuming the initial clear coat will serve as the sealer on the bare wood? I would also imagine that it be a very light layer of clear to begin painting on?
#6 3 years ago
You can print 'white' decals if you use the white water slide decal paper, and let the background color (white) show through. so you're not actually printing white, but by placing color around the white text.... you end up with white text.
12
#7 3 years ago
Good luck mate, whenever I think of doing something similar I remeber the Italian lady who "restored" the old 19 century fresco of Jesus
#8 3 years ago
Quoted from Sonora70:
The initial clear serves several purposes. It provides a uniform surface for the paint like a primer. That way your new paint layer will have a uniform look instead of soaking into the bare wood vs sitting on top of original paint/lacquer. That bare spot would be pretty obvious if you just painted over without a sealer coat.
Secondly if you goof up it's easy to scrub it off the clear and start again.
Thirdly it begins to level the surface. Without being level, even if the final layers of clear are level you'd be able to see clearly the ridges around the area where it was bare.
#9 3 years ago
Studied the playfield again this evening. Anxiety is building. When scanning and making decals can they be printed in yellow and red as well? Places like the gottlieb logo and "SPIN" are concerning me. Sorry so many questions, just trying to do a pregame analysis. At this point the angel on one shoulder is saying go for it the devil on the other is saying to run away. Im supposing Im going to have to replace inserts....another new challenge.
#10 3 years ago
Yes you can print pretty much any color but white on a home printer. It's not super opaque though so you'd probably have to put a decal over white paint or I believe they make white decal paper too. You'd want to experiment to get the right color. When you tell the printer a color to print it assumes you are printing it on white paper.
#11 3 years ago
Vids guide and the input and experiences of others in the restore thread are invaluable.
Regarding the decal / waterslide questions, I just attempted to do a restore almost entirely using decals, there may be some insight for you, documented here…
https://pinside.com/pinball/forum/topic/bally-magic-circle-semi-sympathetic-playfield-restoration
Best of luck,
Guy
#12 3 years ago
Quoted from Moonbus:
Best of luck,
Guy
Nice post! Actually read it before I began my project.
#13 3 years ago
Moving forward. The past couple of days I've been researching scanners and clear coat. Although what I would consider "pricey" at $53 for a quart plus a small can of hardener I managed to get some of the PPG JC660. I wish the scanner were that easy. Over the past week I have seen 1 hp 4600 sell on the auction site for $65 including shipping and 1 hp 4670 that is still in process. Apparently these are the only scanners of their type other than the Doxie Flip which only scans picture size areas. I really don't want to get in a bidding war on technology that isn't made anymore. Short of flipping my playfield upside down on my regular scanner I'm investigating some other options. Other options are certainly welcome if anyone knows of one.
Other than collecting materials, my progress has included taking multiple pictures of the playfield and cleaning. After reading Moonbus' post I'm also thinking about my area to spray. I have my little workroom in the basement but may be taking it to the basement garage for painting. I didn't realize there would be that much over spray from the airbrush.
#14 3 years ago
Moving forward. The past couple of days I've been researching scanners..... Over the past week I have seen 1 hp 4600 sell on the auction site for $65 including shipping and 1 hp 4670 that is still in process. Apparently these are the only scanners of their type other than the Doxie Flip which only scans picture size areas. I really don't want to get in a bidding war on technology that isn't made anymore. Short of flipping my playfield upside down on my regular scanner I'm investigating some other options. Other options are certainly welcome if anyone knows of one.
Hi Sonora70
I bought my scanner a HP 4670 scanner from eBay and use it a bunch, frankly what more technology is needed? It lies flat on the items to be scanned so scans without error, I copy the TIFF file at 300 DPI (1) and bring into what ever program I need. Stitches multiple files with the original software if needed.
It is pot luck on the quality I agree, I guess I lucked out and recommend you go that route.
Cost nor technology really doesn't come into the equation when bidding on eBay for this old but perfect scanner. Worst that can happen is you may need to return if it doesn't work, then buy another one until you are happy.
Steve J.
#15 3 years ago
I've had good luck so far just using the high resolution camera on my smartphone, just being sure it's level with the playfield. This works fine for small areas I think. I also have an old Canon flatbed scanner that I plan to cut away the plastic shrouding enough that the glass can lay flat on the playfield. Would be a little cumbersome but should work. I've been working on other things but if I get around to that I'll report on its success or failure.
#16 3 years ago
I'm not sure how he was set up but there shouldn't be that much overspray. Okay maybe avoid the dining room but a small window fan or even bathroom exhaust fan should be enough to keep particles in the air from spreading throughout the house.
#17 3 years ago
Quoted from polyacanthus:
Haha, I was not setup at all, did not have any extraction as I was totally unprepared and foolhardy. I had never sprayed anything before.
We are still finding yellow dust around the house all these months on. Not that we are living in filth but I took some shelves down over the holiday period and there was yellow residue between the shelves and the wall so it really does get everywhere if not properly contained.
I made a simple tent in the end but for any future projects I am going to mount an inline shower extractor fan to give some controlled airflow.
#18 3 years ago
I mean how much pressure, how much you sprayed, etc. There will be a little overspray buy it shouldn't be filling the air like that!
#19 3 years ago
Playfield stripped and cleaned ready to be cleared. I made several passes with alcohol and ME. Then wiped down several times with Naptha to remove ME residue.
#20 3 years ago
Okay....finally got my first coat of clear down on the cleaned, stripped playfield. I completed the clear about 30 minutes ago. My fear is that I put way too much clear on? My first observation is it looks very "deep". What I don't like is there are several "specks" visible in the finish. What would have caused those to occur? Will they sand out? I plan to go down and bring the playfield back into my shop area for observation and pictures in another 30 mins so that hopefully it will be dry enough to carry.
#21 3 years ago
Pictures of the base coat of clear. Again, MY FIRST TIME EVER spraying clear coat. I'm hoping it leveled out the planking somewhat to make the painting and decal application easier. Tomorrow after plenty of drying time I will give it the feel to see what effect the clear had on it as far as the finish. I believe this first coat of clear may have eliminated some of the painting I was going to do, especially in the "plum" areas. It actually makes it look presentable.
#22 3 years ago
Should I sand the entire playfield before doing my touch ups?
#23 3 years ago
From my limited experience I would say yes as wet sanding would give some tooth to the clear and provide something for any additional layers of paint and clear to stick to.
As per this post in vids guide...
https://pinside.com/pinball/forum/topic/vids-guide-to-ultimate-playfield-restoration/page/3#post-633591
Use 400 to 600 grit wet-sanding and clean as per this post...
https://pinside.com/pinball/forum/topic/vids-guide-to-ultimate-playfield-restoration/page/5#post-779428
Decals requirements are different as I have had some that prefer the surface to be smooth and others that prefer rough depending on the paper supplier so probably best to test that out.
Nothing stopping you painting, another layer of clear and then adding decals before finishing with a final clearcoat.
#24 3 years ago
First clear coat looks a lot worse than the second. Use a fast hardener to prevent crap from floating in and sticking. Sand it with 400 or so and hit it again, you will have a much smoother surface to work with for decals and paint...Use a tack rag to clean after sanding.
Also, I don't spray that when temps are below 60 or 65 degrees..
#25 3 years ago
Quoted from Jjsmooth:
Thanks for the advice.....also glad to know it will get better. Not totally unpleased, but some areas could look better. I have noticed that many of the problem areas are much smoother now than before.
#26 3 years ago
Baby steps....this evening I sanded the playfield using some 500 grit sandpaper. I wasn't sure if I should wet or dry sand so dry sanding won.
After I sanded the playfield I wiped the playfield down with Naptha and decided I would play around a little with the clubs around the circle in the center of the playfield. I took frisket paper and traced one of the good clubs with my exacto knife to make a stencil. After tracing I lifted the stencil and placed it over one of the badly damaged clubs (9 club). It took a couple tries to get it right but once down I brushed some black createx over the stencil. Waiting for the 9 to dry I began touching most of the other clubs with the black paint. After the 9 club was dry I lifted the frisket stencil, really pleased with the result. A couple more to go and I'll have this part of the graphics done. I've decided against using decals in this area when I can use the frisket and repaint. As stated by Vid, frisket paper is great. Easy to trace with an exacto knife and doesn't allow paint to bleed under. Tomorrow evening I hope to repair the 10, K, and A before I apply heat to lock in the createx paint.
#27 3 years ago
Looking good, I would believe wet sanding is the better way to go.
#28 3 years ago
The purpose of wet sanding is mostly to help the cut material to flow away from the cutting abrasive instead of getting stuck and clogging. If your sandpaper is clogging up you need to wet sand. That's why higher grits are wet/dry because they clog more easily. So if you can sand without clogging, dry is fine. That's really the only thing. Wet will also reduce the cutting efficiency slightly because it acts as a lube between the abrasive and the surface.
Also, most people don't realize there are two sandpaper grading systems, FEPA and CAMI that are different like US and metric. FEPA grades start with a P. So 800 and P800 are VERY different! Annoying both types are commonly available. So if you sand with 600 followed by P800 you picked up at a different store you will be going backwards!
https://en.m.wikipedia.org/wiki/Sandpaper
#29 3 years ago
T....Also, most people don't realize there are two sandpaper grading systems, FEPA and CAMI that are different like US and metric. FEPA grades start with a P. So 800 and P800 are VERY different! Annoying both types are commonly available. So if you sand with 600 followed by P800 you picked up at a different store you will be going backwards!
I did not know that. Oh heck.
#30 3 years ago
A busy weekend has allowed me little time to get much accomplished on the Flip A Card. Biggest achievement was "figuring out" the HF airbrush. I had to pick up some extra parts to get everything connected and in use. A tip on the airbrush is that you will need some 1/8" and .5 airbrush connectors and air hose. These are not available at the local hardware, nor do I think they are available at HF unless you get the entire airbrush kit with the air compressor. Hobby Lobby has some but get out your wallet. Ordering online on the auction site will save you 75%. But if you want it now....they got it.
I gained a little ground after getting my red paint mixed to match the red under the pop bumpers. By the way.....I believe the "red" on most of the old wedgeheads is more of a shade of orange. Under the advice of my daughter I went back to hobby lobby and picked up a bottle of florescent orange. This with some red added created the perfect match. Another tip I learned was that I needed to first paint the red areas white. I initially painted them with red but I couldn't get even coverage over the areas that had bare wood. I wiped the red off, repainted white, then got a nice coat of red.
I also completed the clubs in the center of the playfield using the frisket paper traced to make a pattern. However I also have a set back. I tried out my new HF heat gun and got the area too hot while trying to set the paint. It bubbled my clearcoat. I'll be re-sanding which will probably require me to re-paint my clubs as well. @#$%! Part of the learning process I suppose. A step forward, a step back. Not necessarily looking for perfection with this pin, however I do want a nice looking player.
My next step is going to be the yellow areas. Because of some of the original paint being gone and the presence of bare wood, I anticipate painting the entire yellow area white first as I did with the red. I'm also going to begin learning photoshop to try to create my 10 point graphics and the gottlieb graphic and get printed on decal paper.
#31 3 years ago
In the red I can see some spots that should have been filled before I painted. Because this area will be under the bumper I'll accept it as it is but then make sure it doesn't happen out in plain view.
#32 3 years ago
An update, a frustration, and a question. It's been a bit since I last gave an update on my project. Progress is that I have painted the yellow area around the pop bumpers and really please with the results. Now for the frustration and word of caution to anyone considering this type of resto. After much time spent tracing out all the graphics with frisket paper I began spraying all the "aqua" on the playfield. Obviously the largest area on the field. My color was horrible...not a good match, not even close enough that it would work. Hoping for a miracle or just plain ignorance I proceeded to paint the entire area. Bad mistake! So then the decision, do I try to remove the paint or just paint over it. I thought I would try to remove it all using alcohol and a microfiber towel. (this after the paint was on the playfield roughly a week as I didn't want to see it again after based on the terrible color). Not an easy process, especially wanting to save my frisket paper traces covering the graphics. I quit. I now have a terrible green and white (my base coat of white paint I put on under the terrible green) playfield. I think I figured out the color so now I think I'm going to attempt to paint over the white and green and hope I get even coverage with the new color. Some advice here would be much appreciated before I begin. I suppose I could be aggressive and remove all my frisket and added paint down to the clear coat....I cringe to think I would need to start all over especially with the frisket work. Will my paint be too thick if I paint over the layers of white and bad green? Will the final clear coat layers level everything out for me? My goal is to have the largest portion of the resto finished this weekend...lots of rain in the forecast.
#33 3 years ago
you shouldn't have to fill anything in. do your touchups, and then you level it out at the end with layers of clear and lots of block sanding. This is why I end up doing around 6-7 layers of clear by the time i'm done. You clear, block sand. Clear, block sand, over and over till it's flat like glass. you have to use a block sander, or you will never be flat.
#34 3 years ago
Quoted from CaptainNeo:
</blockquo
#35 3 years ago
Finally got a good match on the aqua color. I painted over the mess I created with trying to remove the first green I painted. I thought with the advice of CaptainNeo I could level everything out with coats of clear if the paint was uneven with the number of coats sprayed on.
To my surprise it turned out much better than I anticipated. Although I have some touchups to do, I'm really happy with my results. I'm not exactly happy with the "10 points" graphics with the arrows under them as I tried to save them by trimming around them. I have to figure out a way to fill in black to make them look better. Or, I may have to paint over them and use decals. I'm thinking for a nice look that's what I'll need to do.
#36 3 years ago
My next step is going to be to repaint the yellow area below the club circle and add the yellow point above the "A" club. While I'm spraying the yellow I may repaint the Special lane on the right side that was touched up to make it look better. I will also need to determine the color of the odd circle under the pop bumper not painted yet. I'll paint the white areas under the plastics as well. Now that I have the large aqua area painted I'm a bit relieved. I'm especially relieved to see how well the graphics turned out after using the frisket paper. My next "nervous" area is the Golltlieb and Co. emblem. Haven't figured out what I'm going to do with it yet. I did order some laser decal paper from decalpaper.com. I'll need to find a laser printer somewhere to print off any graphics I decide to print.
#37 3 years ago
polyacanthus thanks for the sandpaper tip -- I also had no idea!
OP, Playfields looking good!! Fun project!
#38 3 years ago
I've been doing playfields for 12 years and didn't know this. I have noticed different cuts with the same values, but I always thought it was because of the brand of sandpaper. This is good to know.
#39 3 years ago
Yes and no. Clearing and sanding will create a level surface, but recessed areas like in the red around the pop bumpers will be visible through the clear. I'm not sure if that's what you're asking. That is, the clear surface will be level for the ball but if you look closely you will see that divet underneath. Will you notice it in play? No.
#40 3 years ago
Happy to find this topic! I was searching for scanner info, and found this. Also a noob at playfield restoration with no artistic capability. I was just going to get my 1975 Little Chief working and put it in the house, but.. the backglass was peeling more than I wanted, so I got a new one... May as well get new legs, bolts, and levellers while I'm at it.. And the cabinet is dinged, so I'll repaint it soon.. And after all that, why put up with a less than ideal playfield? So, full of fear and hope I have read vid's guide several times, and just found this.
I have a few questions at this point: You said you clearcoated your playfield. Did you do that with your airbrush, or shop that out? Did it do a decent job of smoothing down the planking you mentioned? I'm nervous that on mine there is some paint that is flaking and/or planked, and I don't want to lose any that I don't have to, and I don't want to clear and then have to do mega-sanding to smooth the raised planking.
I'll be looking forward to more updates!
#41 3 years ago
Quoted from PinballBillinFL:
I clearcoated with an HVLP paint gun from Harbor Freight. One of the purple $12 guns. I used my shop air compressor. It was easy, just have a way to vent. It did a good job and it removed/filled some of the planking. It smoothed it out so that it became easier to trace my frisket paper and it also filled in areas that after I repainted I couldn't see the planking anymore. You can really see the difference in the before and after pictures in the "clubs circle".
I'm hoping to update my progress soon. Lots of extra hours at work this time of year.
#42 3 years ago
Update:
Things starting to slow down a bit at work so I decided I would continue on the Flip A Card this evening. Really glad I saved some of the green I mixed for the playfield because the "10 Points" near the slingshots didn't turn out as well as I had hoped. My first task was to repaint that area and paint over the print. I have ready the new "10 Point" print that I scanned, repaired and printed off on decal paper. I'll slide those on after I put my first coat of clear on after I finish all my painting.
My second task this evening was tracing out frisket paper around all the white areas under where the plastics rest. It was suggested to repaint the white areas to brighten up the playfield. I was careful to trim the frisket so that I could maintain the black border lines around the area. Overall, I'm pleased with the results.
I think my next step is going to finish painting the yellow areas and finally mix some tan to paint over the last pop bumper area as well as the "300 points" areas at the top of the playfield. Once those two final steps are complete I'll complete the project by clearing the playfield, putting the print back on, and then put the final layers of clear on. My goal is to complete soon....spring is near!
#43 3 years ago
An update to my update. Another slide decal I made was the Gottlieb & Co emblem. I scanned the emblem, removed all the yellow and red, cleaned up the black and printed on decal paper. My plan is to lay down the new yellow, white, and red then slide the new emblem print on. Anyone know of a better way to do this step? Ideas welcomed.
#44 3 years ago
Tonight I touched up the yellow down below the club circle as well as the lane on the right and the yellow in the gottlieb & co emblem. I initially forgot the critical step of painting the areas that have print and areas that have bare wood white first. This is the only way to properly cover those areas with the new paint. I quick wipe with a cloth and alcohol took the first layer of yellow off so that I could apply the white as needed. While painting the yellow area I also drew in the yellow point on top the club inside the circle. I decided not to paint over all the yellow areas. The other areas look good enough and the mixed yellow matched really well with the original yellow. Next will be the tan areas under the remaining bumper and the triangle areas at the top of the playfield that have 300 points in them.
Once the tan is finished it's decision time on whether or not to repaint the purple area. My first inclination is to leave it as is. It's certainly not perfect but it does look good. I keep telling myself this is my first playfield touch up/restore, this is a player machine not a collector's show piece.
#45 3 years ago
If it were mine I'd probably leave the purple but paint around that center bumper as it will be quite noticeable. Also touch up all the black key lines like at the bottom border of the green area, that really makes things pop when the key lines are sharp. You can do that with a fine artist's brush.
#46 3 years ago
Last night I painted the pop bumper area as well as the "300" areas at the top of the playfield. That small addition cleaned up the entire playfield. At this point I think I'm going to leave the purple as is and touch up the key lines as mentioned by polyacanthus. There are a couple other areas I'm debating on trying to get a little better, mainly the kick-out hole. I'm just not happy with how it looks. It may need some serious sanding. I was hoping that painting it the same tan color as the other areas would help but its still pretty rough looking.
It'll be a while before I get the clear coat on, I want to wait for warmer temperatures so that I can lift the garage door to complete that step. So far, for those thinking of doing this process for first time as I have, I've learned that making extra paint is critical! The paint stores well in the little plastic containers that can be picked up at Hobby Lobby.
Between now and the time I get to spray the clear coat I'll focus on making all my decals to attach after the first coat of clear.
2 months later
#47 3 years ago
Any update on this. I just happen to be restoring a flip a card I picked up for $200 as well, and the playfield is a little worse than yours. This whole thread has given me the courage to go forward and start my own restore. Thanks !!
4 weeks later
#48 3 years ago
I've let it be for a while because of the time of year. Hoping I'll get back to it soon, I've been staring at it lately thinking how I would like to finish.
2 months later
#49 3 years ago
Okay, back at it. The rainy days have provided an opportunity for me to get back to the project. I started my day today with a trip to Staples this morning to have my decals printed. They turned out great. I took the touched up graphics on a flash drive along with my own laser decal paper. They printed me multiple copies or less than $1.
When I got home I decided to finish my paint touch ups. I shot white in the center of the "D. Gottlieb & Co" decal and also touched up a couple other areas. 20170913_154433 (resized).jpg
After touching up I then decided to add a couple coats of clear in preparation for adding the decals and leveling the inserts.
Tomorrow I plan to sand the playfield, add the decals, and drop some clear on top the inserts for leveling.
The playfield looks darker after clearing, however I believe that is because of the lighting change from one location to another.
The picture of the cleared surface shows some "specks" in the clear, I'm hoping sanding will remove those.
#50 3 years ago
Got up this morning anxious to wet sand to see how my playfield was going to look. Wet sanding did the trick. All of the specks are gone and the finish is nice and smooth. This gave me the initiative to go ahead and level the inserts (cupped really bad) and try to get my decals on. Leveling the inserts was an easy task, took me nearly 165 ml of clear to level all of them. I had a package of pipets I used to pull both parts of the clear and fill the inserts. As stated by Vid, I made sure I used 2 separate pipets to draw the clear and the hardener as I didn't want to end up with a can of glass.
After I leveled the inserts came my next goof up. I began trying to apply the decals. After about 4 attempts and not liking the looks of my decals, I noticed that the graphics were printed on the protective layer of the decal sheet rather than the decal! No wonder they weren't sticking and looked gray. Another trip to Staples and I had good looking graphics printed on the correct surface. (if you're going through this process, be sure to remove the protective cover, it's on there pretty tight). When I got home I applied the decals using decal setting solution as mentioned by Vid. I must say I am impressed with the results.
At this point in my playfield restoration education I've learned that much can be cleaned up and made nicer after sanding the clear that's applied after the touch up/painting is done. The borders of the paint colors are nice and smooth and appear "factory".
I'm eager to complete the process with my final coat of clear. That will happen in a few days. I want to give the inserts plenty of time to cure before sanding those. I figure approximately a week and I'll try to smooth them down and do the final. Will update then.
700
Fort Ann, NY
$ 4.00
$ 65.00
Texas Pinball
$ 5.49
$ 9.95
Apparel - Unisex
Pinball Wheezer
$ 79.00
Lighting - Under Cabinet
Arcade Upkeep
$ 149.99
$ 69.99
PinballBulbs
$ 109.99
Playfield - Plastics
Judge Dredd plastic Out of stock
$ 109.00
Cabinet Parts
Tilted Pinball
$ 110.00
AMCO
$ 22.00
$ 229.00
Music City Pinball
$ 18.25
The MOD Couple
$ 395.00
M&M Mods
Docquest Pinball Mods
Apparel - Unisex
Pinball Wheezer
