Ok...never done this before.....nervous! This seems like a daunting task. So many little parts and pieces....should I not even attempts this?? TIPS...TRICKS...TACTICS....??
I need to replace the springs on my plunger as well.....how do I take this thing apart?? I looked inside and seen a faceplate pressed up against some gauged wiring....does this thing secure the plunger rod??
As you can see from the pics...this one is dirty and has some slight wear near the corners of the rebounds above the flippers...and bubbling near the right YARGOV outlane...not sure why is does that??
Soooo yeahhhhhh....LET ME HAVE IT!!
