I will be picking up my first pinball tomorrow... like the title says I went retro but have some work to do. I found this game locally and am 100% pleased with the condition with a single proviso, thus this post.
The back glass is 100% perfect, amazing, like new. This sold the game.
The game is also fully functional although the flippers are VERY weak.
Question is related to play field and restoration. Here goes-
Play field is "rough" in two ways... one- the colors are pretty muted and it appears to be covered with a varnish or dirt layer that is very yellowed- I am not worried about this. Second reason I think its rough, in a few sections- principally near the flippers in the center of the play field the wood grain is raised and the paint is cracked. There is a single minor divot with missing pain near a kicker (this should be easy to fix).
How should I approach the raised grain of the play field and the cracked paint, I am not overly worried about having to spend some time repainting so here is my plan... can you offer some help/suggestions/revisions.
1) Clean the play field throughly, using Magic eraser and isopropanol (91%) in areas with no raised wood grain. Then clean it with Novus 2, then sand and prep for touch up and clear.
2) for areas with wood grain... I was going to go with a prewax car cleaning solution to work on the regions with raised wood grain (worried the magic eraser will do more damage than good) as well as maybe a solvent so get the dirt out and the yellowing out, as well as Novus with a foam pad.
2a) Then- I was going to "power sand" this to near level, but carefully so as to not strip paint from adjacent "good areas". Then, touch up/paint as needed.
So... good or bad?
Finally, inserts are slightly cupped- I cannot get a ball to sit in them its slight... so after touch up I was going to clear coat them using the "puddle" method, spray the playfield and THEN sand them to level and repeat puddle if needed. Then sand to 600 grit wet and finish coat 2x using an automotive clear. I have a very high quality HVLP sprayer and some experience finishing furniture so I am not too worried about the clear... but have never played with touchup/restoration work on anything at all...
I almost want to tune the flippers and enjoy it a bit, but somehow, the project is calling and I think I will just take it apart the moment I get it home. I ordered up new coils for the flippers (probably not even the problem from my reading, but it can't hurt I figure) and will swap those in somewhere along the line.
