I've been restoring a Gottlieb Snow Derby and am now going through its first-generation Decagon score reels. I've noticed that one of the solenoids is oriented the opposite of the others (based on which side of the long spool-end says “Gottlieb” and which says "A-9154”). All but one of them have the black ground wire soldered to the lug on the side stamped “Gottlieb," the other one has the ground wire attached to the side stamped "A-9154".
This definitely an all-AC pin, but even so, wouldn't wiring it one way pull the plunger in and the other push it out, or does it always pull the plunger toward the lug end of the spool regardless of which way it's wired?
