So completely out of the blue, I have ended up with my first pinball cabinet! A lovely little F-14 Tomcat, which I hear is a nice starter cabinet. Disclaimer: I've worked on plenty of arcade machines before, but pinball is new to me. I have friends up in Maryland with knowledge (Richmond, VA here) but it's hard to keep logical correspondence going on something like this. There were a few things wrong with it -- needed a couple of flippers, a shooter, a few lights out, some switches needed diagnosed, backboard lighting didn't work, etc etc, but I was able to get all of these working.
On to the biggest thing that's given me a headache though: these bloody diverter coils. Knowing nothing about these, I managed to lift the playfield and find the top diverter [leads to right side] completely toasted. Fair enough, and the other worked as intended. Ordered a new coil, installed, wired up, and coil test still showed the same thing: nothing on that diverter. Weird. Next step was to try to diagnose, and it's a bit hazy here, as I was fiddling around late at night and now, neither of them fire. In fact, when wired up the way it was when I purchased it, the previously-working diverter is now stuck ON/ACTIVATED. Crap.
So what have I done already? Why am I posting what's been posted a few times already? Well, honestly, because I want to make sure my situation fits the description of the others clearly. I've completely disconnected the top one, leaving me to diagnose the problem with the one that WAS working. When I disconnect the ground and manually trigger it at the coil, it works, but when hooked up to the cabinet, perma-active. Bad. I scoured through the schematics and the manual (holy crap that was more than I expected) and found that Q77 and Q79 transistors could be the culprit. Ugh, board work -- not what I expected, but I'll take it on. Took the board out earlier today, replaced both of these transistors with TIP122s, and exact same issue still.
Now I understand that people have recommended replacing some resistors and Q78 as well, so these parts are in the mail currently. As far as I can see, no fuses are blown, and I'm a bit weary of manually grounding anything else to diagnose because admittedly, I touched the ground to the wrong side of the working coil and had a micro-second of humming and flashing, I'm learning. Figured that may have blown the diode on it, but since I had another one of them, I replaced that, and same issue still.
I'm totally at a loss here just trying to find some direction while I wait for those parts to get here because I'm not entirely certain they'll fix it, and board work is soooo much fun :l
