So my fire power will not start a game. Usually, this is because the ball trough does not recognize all three balls. I adjusted and cleaned the switches, but that did not help. Pulled the battery off the rottendog board and reset everything to free play, still not help.
I went into diagnostics, and sure enough switches 57 and 58 do not register. Both switches are on column 8 of the switch matrix - conclusion there is a switch matrix issue on column 8.
I took the following picture of the wiring for switches 57 and 58 - is this a hack and the cause of the problem? Note the yellow wire connecting switch 57 and 58.
