(Topic ID: 333951)
FirePower Weak Knocker Issue!
By Pinball-DOOD
1 year ago
  • 13 posts
  • 6 Pinsiders participating
  • Latest reply 7 months ago by phishrace
#1 1 year ago
Hey all,
Recently, my FirePower knocker has been super weak! I went ahead and replaced the Q41 driver and pre driver for that knocker hoping that would fix the issue but it did not! Could the coil just be bad? It just sort of hums and the plunger barely moves. This plunger moves freely when I move it through the coil with my finger. Any ideas? Thanks!
#2 1 year ago
Take a resistance/ohms reading from the coil and report back.
#3 1 year ago
Quoted from frunch:
Will do! Diode test?
#4 1 year ago
You want to use the resistance/ohms test--it will have the omega symbol: Ω
#5 1 year ago
Quoted from frunch:
Sure! Thanks! Will get back to ya
#6 1 year ago
Ah, looks I am getting 4.4 ohms which is good
#7 1 year ago
Quoted from Pinball-DOOD:
Hey all,
Weak coil after testing OHMs:
Connect a wire to ground, with power on, ground Q41 Tab
Coil still weak?
Ground Knocker coil Lug (brown -Blue wire side)
Good?
suspect short in harness at connectors
Reseat solenoid and cabinet plugs between head and cabinet.
#8 1 year ago
Quoted from PINTEC:
Coil still weak?
Good?
Okay, sure! Will look into this, thanks!
#9 1 year ago
Quoted from PINTEC:
Coil still weak?
Good?
So when firing the coil manually via a wire (I have one with miniature alligator clips), can I clip one end to the ground strap and then touch the other end to the tab of Q41?
#10 1 year ago
That's what I would do.
#11 1 year ago
Did you try a new coil sleeve and inspect the plunger for burrs?
5 months later
#12 7 months ago
Finally have the chance to look at this issue again! Should I replace the coil?
#13 7 months ago
You should do what was suggested in the first reply you got five months ago. It was good advice then and it still is. If you don't know how to use a meter, ask for help locally or start learning.
2,900 (OBO)
Hawesville, KY
Tools
Pincoder Store
$ 299.95
Pin Stadium Pinball Mods
600 (OBO)
Casper, WY
$ 170.00
Displays
Digipinball Shop
$ 42.95
1,400 (Firm)
Benton, PA
Trade
Machine - For Trade
Washington Court House, OH
$ 27.95
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/firepower-weak-knocker-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
