Pretty simple question on this one, hoping someone else has seen something similar.
Firepower running RottenDog 327. Works great unless you hit both flippers simultaneously, then it resets and puts the machine into attract mode. I realize the double-flipper reset is a known thing and I'm going to work through the steps to troubleshoot, but most of those steps were built for the original PDBs...or maybe there's a Rottendog one somewhere? Anyways, I noticed something when testing with the backglass off: LED1 and LED2 on the RottenDog board are both off all the time, and they only light up RED (both at same time), then quickly shut off, when the reset happens. Would those LED firing up point me in a certain direction for diagnosing the problem?
I'm really just trying to avoid having to tear off, test, and re-solder each diode if I've got something silly going like connections between boards here. Hoping these little LED lights are pointing in a direction.
Thanks for any help.
