My Firepower currently has two issues:
In about 1 out of 5 times, Firepower will start a game automatically when you turn it on. The start switch is not closed mechanically and it doesn't show up in switch test as closed.
The game often shuts down mid game but I can't associate it to a coil firing. It's happened when I'm about to shoot the ball with the plunger and when the ball is nowhere near a switch or coil. The displays go blank, coils go dead, but GI is on and sound is still going as though nothing happened. The game does make a noise that sounds like something is being energized in the cabinet upon boot up. This only happens if the game has been of for a period of time, then turned on (10 or more minutes) Speaker maybe? Occurs for about 2 seconds then shuts off...not sure if this is normal.
I picked this up as a project that was having issues keeping memory and booting. I replaced the 40 pin, all header pins on the CPU/MPU, new lamp resistors, and did the combo rom mod. I haven't touched the power supply board yet. All insert lights, displays, and coils are working during game play and in test mode. The sounds appear to be working fine.
Where do I begin?
