Firepower Restoration (it has begun, back in action)
(Topic ID: 151401)
By beatmaster
2 years ago
  • 379 posts
  • 41 Pinsiders participating
  • Latest reply 3 days ago by MustangPaul
  • Topic is favorited by 60 Pinsiders
There have been 196 images uploaded to this topic. (View topic image gallery).
power supply 12V:15A:180W (resized).JPG
There are 379 posts in this topic. You are on page 6 of 8.
#251 11 months ago
That's pretty much the same way that I highly polished all of my playfield rails...it works great!
#252 11 months ago
update on the airbrush.
half airbrush, half stencils.
the new planet on each side.
#254 11 months ago
Thanks for posting all the sanding pictures. That is a lot of hand sanding.
#255 11 months ago
Quoted from BJM-Maxx:
no problem, if it can help somebody why not.
#256 11 months ago
Thanks for the polishing process pictures !!
#257 11 months ago
Quoted from HPR:
you're welcome max, i know this is something you can do.
#258 11 months ago
What are you doing to protect the metal after you're done polishing?
If you're not coating it with anything, won't the steel rust again with moisture?
#259 11 months ago
Quoted from brenna98:
Probably a good wax, that's pretty much it.
if this rust, then every other pieces in the machine should rust also.
like i mentioned before, i did a few pieces years ago, still look fine.
#260 11 months ago
Quoted from beatmaster:
I realize now how much time is necessary to realize those nice lockdown bar.
I will certainly try to polish one bar that way this summer
This Firepower restoration is out of control !! The result will be amazing
#261 11 months ago
Nothing crazy today, just painted the speaker grill, backbox grill and the grill between the cab and backbox.
Backbox:speaker grill (resized).JPG
Backbox:speaker grill (done) (resized).JPG
#262 11 months ago
oh and more metal parts to do
not sure when, maybe sunday or monday.
going to my brother in law tomorrow to see the airbrush job in person.
#263 11 months ago
a lot of sanding and buffing.
Here's the rundown;
(the key) i started to sand the lockdown bar with a 100 grit sand paper, next 180 (i might use a wheel on this one), 280, 320, 400, 600, 800, 1000, 1200 all that always in the same direction, always.
Buffing, i also like to use a power drill with buffing wheels, it gives me a better control in general and in tight spot.
The thing with stainless steel because of the texture it takes a lot of time, i can spend 15 - 20 minutes with a 100 grit sand paper alone, same for 180, as you go up it becomes smoother so it's a lot easier, at 600 it starts to shine, at 1000 it's pretty smooth, 1200 you remove all the fine lines (before that for the bigger ones). most of it by hand (a lot of time and elbow grease).
buffing,
good buffing wheels and paste.
i always use the same wheel with the same color (green for stainless steel), another to remove left overs and another wheel for final buffing (depending on the area i might switch between size or shape).
i always (most of the time, depending on the piece) buff in the same direction.
it's not easy but after a few pieces you get the idea, don't stay too long in the same spot, apply just enough paste on the wheel etc...
- i already the did 100 and 180 on the rear glass channel tonight, should be done tomorrow.
Mods should mark this and a couple others as key posts. Great info.
#264 11 months ago
So today i decided to clean the backbox sheet panels, because it's big and it's in my way.
took me all day to clean this, it was a pita to remove the old stickers, had to use good old goo gone.
#266 11 months ago
beatmaster I am a little shocked that you didn't make new panels
#267 11 months ago
Quoted from eh97ac:
oh trust me it went through my mind. i wish they already exist somewhere (not sure, i think it does).
but i said to myself most of it will be covered so...
#268 11 months ago
some cleaning and buffing, no sanding before buffing this time.
lane guides on the playfield.
#269 11 months ago
I did the same, looks great. Bear in mind, you will wind up with a ball-roll streak on the lane guides in the middle. No way around it.
#270 11 months ago
Quoted from La_Porta:
yep that's exactly why it's not worth it.
#271 11 months ago
Well, I still wanted a mirror finish. I like it how it came out. The lower flipper guides, however, look great buffed.
#272 11 months ago
just finished the bracket/rod/bar (whatever we call it) to support the playfield in the upper position.
nothing crazy, a little bit of sanding and buffing.
looks much better now, at least it's clean.
#274 11 months ago
update on the cabinet (airbrush).
spaceships on each side of the cabinet almost done.
#275 11 months ago
Now THAT is cool!
#276 11 months ago
Now THAT is cool!
thanks, i'll let him know.
the stencils are almost done for the spaceship, a lot more will be added.
more stuff on the cabinet, stars, the dark moon, firing blasters (planet, spaceship), explosions.
i know he started to work on the front of the cabinet, i saw a little bit of it.
when all stencils are done, airbrush will start.
#277 11 months ago
found a brand new speaker for the cabinet.
now, i need to make a sticker for it.
#278 11 months ago
just received another picture, all stencils done.
shadow, highlight, cleaning up the overspray, etc... will be done later.
#279 11 months ago
I ALWAYS look forward to seeing what's been done.
#280 11 months ago
sticker for the speaker, first or second?
#281 11 months ago
First, you already have enough space ships on the game.
#282 11 months ago
Quoted from MustangPaul:
yeah but that'd be the only one inside the cab lol.
i kind of like the second one
#283 11 months ago
That's what I think of your second one.
#284 11 months ago
Isn't the Speaker supposed to be a 4 ohm speaker?
#285 11 months ago
First one.
#287 11 months ago
Might as well make some new instructions/free play cards. ** Fixed **
#289 11 months ago
I'm glad to see a special earns a credit and none of that xtra ball shit.
#290 11 months ago
Second one for the speaker.
#291 11 months ago
Quoted from Travish:
i just went with the original card but there's another one with an extra ball award, and in firepower an extra ball is a good thing.
#292 11 months ago
just made the test with both on the speaker, not a sticker yet (cut by hand, as you can see i'm very good lol.)
baaaaaaaah they both look good but i do really like the spaceship one.
#293 11 months ago
Spaceship one for sure
#294 11 months ago
Geez seeing them both on the speaker i'm thinking that first one seems to pop, a 'less is more' kind of thing.
#295 11 months ago
Spelling alert! Second instruction line - should read "Flashing" not "Flasing" and "locking up" not "lockind"
and if you are sharing - would love to print a set of these for my Firepower project.
#296 11 months ago
Quoted from aztarac:
Hey that's how they spell those words n Canada.
#297 11 months ago
all fixed, added stars also.
they are ready for printing, just add/drop to an 8 x 11 document and print away, high definition, glossy photo paper.
#298 11 months ago
how can we spell, can't even fuckin' read, lol.
#299 11 months ago
Oh don't be so hard on yourself, mistakes happen.
#300 11 months ago
next step,
the tilt bob/ roll tilt panel and wire harness on the left side of the cabinet.
i might reduce the size of that panel, it's too big for nothing, depending on how my power splitter board fit.
repaint the piece of wood, probably black.
cleaning the wire harness.
new tilt bob assembly.
polish the roll tilt assembly.
new flipper leaf switches.
might add a volume control.
add an extra set of wires so i can connect my power supply directly with the cabinet power switch, that way when i power up the machine power supply turns on at the same time.
pinball life 8 way splitter board for all the great mods, connected to the power supply in turn connected to the power switch.
and a few other things.
** yep, the power cord was YELLOW ** gonna change that for black.
tilt bob:roll tilt panel (before) (resized).JPG
Thorndale, PA
Milwaukee, WI
$ 104.00
$ 18.00
Yorktown Parts and Equip
£ 49.00
PinballToys
$ 29.99
Full Tilt Pinball LEDs
$ 49.99
$ 69.99
Bright Lights Pinball
