Picked up a firepower a while back. Getting around to getting it working, no boot, did the 40 pin and realized power supply caps were bad shape. decided to start at the beginning.
Went ahead with rebuild of power supply, trying to test with no connectors (besides power input) hooked up.
Replaced 4 caps, upgraded the 2 rectifier diodes and replaced the 5V voltage regulator and reflowed all the connectors. (mostly based on http://pinball.flippers.info/system6repairpart3.asp & other likely guides/advice around on system 6 machines)
Testing the power supply with nothing hooked up. I get 12v where I should, and 100v where I should on the output connectors
Had odd results, getting .6-.7v on the 5v connector pins. Tested it with the board unhooked and getting the same on the output pin of the voltage regulator (backside). Tried it with a different voltage regulator, same thing.
2 different brand new LM323K same problem. What am I missing?
