(Topic ID: 98871)
Firepower not starting a game now.
By Arcade
9 years ago
  • 43 posts
  • 12 Pinsiders participating
  • Latest reply 9 years ago by Arcade
#1 9 years ago
Just got a broken Firepower last week. When I got it all that it did was light up the GI.
In the last few days I have replace both male and female interconnects.
Replaced all caps on power board,.
Replaced lamp resistors.
Replaced most of the Scanbe sockets. Still have 4 left to go but none in stock locally at the moment.
Took the battery holder off the board.
After doing all that I put all the boards back in and powered it up.
Opened the coin door and turned the machine off and on quickly and the game boots into attract mode.
Used the coin switch to put credits on the game.
Pressed the Start button and got a ball served up and the game played great. Or so I thought. lol
After flipping the ball around a bit and everything working great the ball went into the kickback. The coil locked on and blew the solenoid fuse.
Replaced the fuse and started booted the game back into attract mode and now after taking credits the start button refuses to do anything. Just dead. Cleaned the contacts and still will not start the game anymore.
Any ideas are much appreciated.
#2 9 years ago
As usual, check the trough switches. These may be bad even if they look good, and have been cleaned.
For years, Williams switches were assembled backwards - instead of contact to contact, they were contact to rivet. Not a problem in EM games, but a BIG problem in aging early SS games with gold contacts.
This is very easy to see if you look at the switch. If those trough switches are the original bad ones (and they likely are) it is very common that you'll have this issue. The effect of these backwards switches can be felt particularly bad in places where the balls sit - mainly the outhole troughs and the lock holes.
You can disassemble to switch and turn the rivet one around, or just replace the switches with new ones.
#3 9 years ago
Quoted from CrazyLevi:
Awesome info.
This is why I love this forum.
Thanks Levi.
#4 9 years ago
Stupid question but are all 3 balls in the trough? If one of the balls is still in one of the lock saucers, it will not start. The game will normally eject any balls left in saucers but that may not be working if the saucer switch isn't registering.
#5 9 years ago
Go into diag and see if the start button is recognized in switch test, along with the trough switches.
#6 9 years ago
It was a switch.
The game is working almost perfect now.
The top right pop bumper is sticking on and the coil is heating up. Did not have time to check if it is a stuck transistor or a bad release switch under the playfield.
If it turns out to be a transistor, does anyone with a manual know which one controls the top right bumper?
Here is a photo of my switch problem. A wire had somehow come completely off. Got it soldered back in place now.
Very strange that it even started the first time.
#7 9 years ago
I've had problems with my start button as well. Check the coin door button. Press that a few times... That will fix my start button.
#8 9 years ago
Top Right Pop is solenoid 19, Q6 driver and Q5 pre-driver.
Now that you have a Firepower, you need to check out http://www.firepowerpinball.com/
Great documentation out there that can also be helpful for any System 6 machine...
#9 9 years ago
Thanks. I briefly looked at that site but for some reason it is so small on my screen I can hardly read stuff
#10 9 years ago
Awesome job Arcade.. You stole that Firepower my friend. Welcome to the Club.
#11 9 years ago
Went ahead and removed the driver board and took it over to my work area.
Both the Q6 driver and Q5 predriver test good. No dead shorts and they both give me the exact same values as the ones around them.
I went ahead and changed them out anyway but no dice, the coil still locks on when a game is started.
I replaced the coil as well and that still did not work.
I replaced the diode on the switch as it looked a little corroded and still the coil locks on when I start a game.
(Most of the time anyway). Sometimes it will let me play an entire game where the pop bumper works just fine and then the next game it will lock on.
I still have a few Scanbe sockets to replace, but I'm not sure if they would be causing this one coil to have this crazy problem.
Any ideas much appreciated.
#13 9 years ago
Just a bump as I edited two posts above as to what is going on with my stupid pop bumper coil.
I am starting to grasp at straws on this particular problem.
Once it is solved all I will have left is the player 1 and 2 displays do not have all the segments working.
#14 9 years ago
Measure the resistance across the capacitor that is on that pop bumper switch. It may have failed shorted. Almost every cap on the two Firepower machines I have, had the caps cut off by the operator that owned them.
If the cap measures close to zero ohms, cut one leg off to confirm that was the problem. The machine will operate OK without the cap (will not harm anything).
#15 9 years ago
Thanks Schwaggs.
I had read about cutting the cap off and it would still work, just not as powerful.
And since that is the only part (other then the IC chips) that I have not changed, I feel pretty confident that it may be the problem.
Maybe that would explain why sometimes the coil locks in immediately and sometimes it lets me play for awhile before deciding to lock on.
#16 9 years ago
Well after cutting one leg off the cap, the pop bumper still locks on when I start a game.
So here is everything that is not causing it to lock on.
1. Not the switch being stuck on. And no solder has dripped and no tabs are shorted on the switch.
2. Not the Driver or predriver at Q5 and Q6 (replaced them both)
3. Not the coil or the diode on the coil (replaced them both)
4. Not the diode on the switch. (replaced)
5. Not the cap on the switch. (took it off)
The only part of the switch that I have not messed with is the tan colored diode or resistor. (Not sure which it is).
Not sure how to check and see it it is good or if it would even cause this problem.
What else could possibly be causing this to happen? It is the last fix before we can actually play a game and it is driving us nuts.
#17 9 years ago
I found a thread on here where I guy had the same thing happening.
Unfortunately it never got resolved in the thread.
But someone did think it may be a bad IC chip.
Here is the response below that I guess I will need to check on.
"Next test the associated 7402 and 7408 TTL ics. Power off. DMM set to diode test. Red lead on ground. Black lead touch the associated pins on the 7402 and 7408 ICs. Again you should see .4v to .6v. A lower or short is indication of bad TTL chip. Use the schematic on IPDB to find the associated 7402/7408 pins".
#18 9 years ago
Sorry for talking to myself, but this helps me. lol.
If I am reading the driver board schematics correct on firepowerpinball.com the two 7408 chips I need to look at are IC 6 and 7.
And the two 7402 chips I need to look at are IC 8 and 9.
Can someone with more knowledge then me confirm this would be the IC's that would short and drive this pop bumper coil?
#19 9 years ago
Well, your self-talking will help me someday. Most of this is over my head, but I'm reading it all.
#20 9 years ago
Keep reading, because one way or another I will get this damn thing fixed.
#21 9 years ago
Just checked all 4 of those IC chips. They all 4 test the exact same. Just the two ground pins on the ends beep.
Still ready for any more ideas on this. Pulling hair out now.
#22 9 years ago
if the coil locks on at game start, there's an input switch problem.
to diagnose this, remove the (i think) top left most connector from the driver board. this connector is the pop bumper/slingshot (special solenoid) inputs to the driver board (they are not part of the switch matrix.) Do this FIRST, do not cut the caps off the bumper switches!
start a game. coil not locked on? if no coil lock, then probably the switch cap is at fault. Or the switch is adjusted too close. Or a solder blob on the side of the switch stack. or a pinched wire going to that (removed) connector. something like that.
if the coil is still locked on after game start with this connector removed, then the problem is on the driver board. you'll have to break out the schematics and trace the circuit.
basically what happens is there's two inputs to a TTL chip on the driver board. One is the direct switch on the pop bumper, the other comes from the PIA. if either is "on", the coil turns on. Or if this chip is bad, the coil will turn on. Usually it's the 74xx chip that's the problem, but sometimes it's the PIA. you can use a logic probe to check. Just have the second connector down on the left side of the driver board removed so the coil doesn't energize.
There is one other thing that could happen... on the driver board special solenoid switches there's a zener diode for the special solenoid switches. sometimes these short. Wait a second, that's system11... i pretty sure system6 didn't have that. (the diode is a circuit protector.) i don't have a schematic in front of me, but i'm pretty sure that's system11 only.
#23 9 years ago
Thanks a million. I will get right on that
#24 9 years ago
Ok. The coil energizes with the top left plug pulled out. So we have a chip problem.
I have replaced four of the seven 24 pin scanbe sockets. I still have 3 to go but my shop is out of stock.
I also still have to replace the 40 pin one as well which I can do on Monday.
However I do not own a logic probe and need to find out exactly which 7402 and 7408 chips to check.
Any way to do it with a multimeter? If not I would just have to replace the ones that control the top right pop. (I dont get any dead shorts or strange readings by putting meter on diode mode and touching red to ground strap and black to the non ground pins of the chips).
I really appreciate the help. You confirmed that I was on the right track with the IC chips
#25 9 years ago
OK. Here is where I stand so far with the top Right pop energizing at game start up.
I have replaced the 40 pin PIA chip and chip socket and no help there.
I also replaced IC 8 on the driver board with a new 7402 IC. I did this because after tracing the traces on the board from Q5 and Q6 this is the first chip they go to. But putting a new chip here did not help either.
I do have a brand new PROM board coming from Hans with the latest software and I will also be able to remove the 6 IC chips on the bottom of the CPU board as well. No idea if this will help with my problem or not.
If anyone has any ideas on which IC chip is causing my top right pop to energize, I am all ears. I am fast running out of things to replace so something has to work eventually.
#26 9 years ago
Just looked at the schematic. The drive path for the top right pop is PIA IC11, IC6 (7408), IC8 (7402), Q5, Q6.
If you didn't replace IC6, I would try that first.
There are 3 PIAs on the driver board. Which one did you replace?
#27 9 years ago
Quoted from Arcade:
you sure its a chip at all? i have seen exact issue on a perfectly good boardset. To fix it I changed the capacitor on the pop. ( just lift / snip a leg to prove if its the problem) If not then its easy to resolder it
#28 9 years ago
Thanks for posting the entire path. That will help a lot.
And yes to the question of am I sure it is an IC chip.
The pinball Ninja himself helped me narrow it down pretty quickly.
#29 9 years ago
I will try IC 6 tomorrow.
I have not touched any 40 pin PIA's on the driver board.
The 40 pin I replaced was IC 1 on the CPU.
I had no idea IC 11 on the driver board had anything to do with special solenoids.
Oh well, live and learn
#30 9 years ago
Wow. After taking a look at IC 11, it may well be the problem.
Do IC chips leak?
What would this crap on mine be?
I was able to wipe it off with a paper towel but have no idea what it could be.
IC 6 of course looks great.
#31 9 years ago
Same chip after a light cleaning,
But the first three pads look dull and maybe even a cold joint on the first one.
I do not have a spare 6820 chip laying around so I will need to order if this is indeed the problem.
#32 9 years ago
Quoted from Arcade:
Do IC chips leak?
I do not remember seeing that yesterday when we had the boards off. Do you?? I feel sure I would have noticed as much as we've looked at those boards.
#33 9 years ago
I don't believe there is any material inside a 6821 that will leak. A catastrophic failure of the chip usually results in part of it burning or in some cases part of the plastic casing blowing off. Are you sure you haven't spilled something on it?
Do you have a logic probe? - it will make testing fairly straightforward. If you have replaced Q5 and Q6 as well as coil and coil diode then I would start with pin 4 of IC8. Remove pop bumper solenoid fuse, switch the machine on and start a game.
If everything is OK you should have the following results with a logic probe:-
IC8 pin 4 low, pin 5 high, pin 6 low
IC6 pin 11 high, pin 12 high, pin 13 high
Report your results. If you don't have a logic probe let me know and I will test with a DMM.
Andy
#34 9 years ago
What you're seeing under the PIA is likely damage from the batteries leaking above. Anything under the batteries is fair game without any rhyme or reason. On one driver board I had leaking batteries took out the end of the 40 pin and the 2J5 lamp drive connector but didn't touch anything in between. Go figure.
Unfortunately, without removing the PIA you have no way of knowing whether or not you've remediated all the acid under the chip or if the traces are damaged.
viperrwk
#35 9 years ago
Thanks guys. I will go ahead and replace IC 6 today and put a socket on IC 11.
I have a new 40 pin chip in my cart in case this one is bad.
I did not spill anything, that is the way it came to me.
#36 9 years ago
And I do not have a probe. Just DMM.
#37 9 years ago
I have to go shopping with my wife, but when I get back i can try the new IC 6 chip out.
I also removed IC 11, added a socket, cleaned the traces, and lightly sanded it's pins. (May still need a new chip).
Not sure why pin 1 on IC 11 has that empty trace running up to it that nothing goes in.
#38 9 years ago
Success!!!
Now I just. See to get the top segments on players 1 and 2 working.
I have tried swaping out displays but players 1 and 2 are both missing the top line.
Any idea what part might be causing this?
#39 9 years ago
Congrats on the solenoid drive repair!
Now it's time to look at your master display board. There are 2 types, I'll assume yours is the more common type with a bunch of ICs. At the top left side is a row of 7 resistors, all the same value (10k ohm 1/2 watt) These are known to burn up or go high in value. R1 is the one tied to the top segments of players 1 & 2. Pray that this is the problem because the next suspect will be IC9 (UDN7180) These chips, if you can find them, are very expensive.
#40 9 years ago
Quoted from mwsmith:
Awesome. I have the resistors from the last repairs on my Williams Hot Tip.
I remember now that the UDN7180 are hard to find. Last time it came down to taking a chance on a china knockoff, which I hear are sometimes not even the correct chip, or getting a new X-Pin LED board set. (I went with the X-Pin LED board set on that one.)
#41 9 years ago
OK.
I changed out the resistor and no help with the top line of the displays.
Not sure if it matters but the top lines on the master display are out as well.
Only players 3 and 4 work perfectly.
Now on to the fun part.
I still have my old board from my Williams system 3 game.
However it has white UDN7180H chips in it.
My Firepower board has black UDN7180A.
Are these even interchangeable?
I was thinking maybe I could pull one off the system 3 board and try it on the System 6.
But I have never tried to de-solder one of these white IC chips before.
Here are photos of both boards. (Top photo is Firepower and bottom is from a Hot Tip)
Hate to have to buy another LED board set if I don't have to.
#42 9 years ago
Quoted from Arcade:
OK.
IC9 drives players 1,2 & master.
The chips are interchangeable, the black is a plastic body, the white is ceramic.
Make sure all the 10k resistors are good. I see 2 on the right (R11, R12) in your photo that look burned, but they are for players 3 & 4.
#43 9 years ago
I thought you might notice those. My brother and I kind of burnt those by accident.
We decided to just move the cables from one player to another to see if the problem followed the cables.
Well, we moved player 4 up to player 2 and let player 2 wire just hang there.
Big mistake as smoke quickly emitted from those two resistors.
However I guess we cought it in time as player 3 and 4 still work great.
$ 129.00
Cabinet Parts
Bob's Pinball Stuff
$ 44.99
Pinball Shark
$ 27.95
$ 42.95
Tools
Pincoder Store
2,900 (OBO)
Hawesville, KY
Trade
Machine - For Trade
Washington Court House, OH
600 (OBO)
Casper, WY
$ 170.00
Displays
Digipinball Shop
2,200 (OBO)
Branford, CT
This page was printed from https://pinside.com/pinball/forum/topic/firepower-not-starting-a-game-now and we tried optimising it for printing. Some page elements may have been deliberately hidden.
