Hi everyone,
So I took to doing some repairs and upgrades on my FP. I replaced the flipper bats, bushings, and the majority of the mechanism of the left flipper. I also have been progressively cleaning out areas of the PF, including the ball locks. Last night, I cleaned the leftmost one. It has worked with no issue since I got the game.
Tonight, I noticed that after I replaced the flipper parts that lane change was not working. I tracked it down to a wire that had become dislodged from the lane change switch (likely while replacing flipper parts), so I re-soldered it. Lane change works fine now. When I went to try out the new flippers, the first time I shot the ball into the left lock, it became lodged in there, but did not kick out (the lane was not lit at the time). I attempted to trip the switch manually, to no avail. So, I put the machine into diagnostic mode, and the solenoid for the kicker itself works with no issue. So, I assume that the switch itself is the issue. I cleaned the contacts, checked the wires and the diode for the switch, and nothing seems to be amiss at least to the naked eye.
Could I have done something while re-soldering the wire in a seemingly unrelated part of the board? Could my cleaning of the lock have inadvertently done something last night? I can see nothing wrong with it, and nothing else on the machine is not working to my knowledge. I tested the other two locks, and they function normally.
I am very new to this and attempting to get my feet wet with electronics, so bear with me. Suggestions?
