I just received a very nice firepower playfield thanks to another pinsider. I am going to clean it up, and swap out my existing playfield which is worn to the wood in a lot of places. I am using a magic eraser and alcohol to clean the playfield and that is working well.
The bottom half of the playfield - basically starting just above the hotdog shaped inserts "fire" and "power" - has been covered in mylar. The mylar is also over the the original half moon mylar in front of the sling bumpers.
I have read different threads about using heat or freeze to remove. I have tried the heat method in the past with mixed results. I have noted several folks saying dry ice works well. It certainly is cheaper than freeze spray. Any thoughts on using dry ice?
