Hi all,
Got myself a pretty beat Firepower and been busy shotguning the boards since.
Now everything works perfectly except for the Match that displays 02 constantly.
Any idea on how to troubleshoot that?
Hi all,
Quoted from manples:Hi all,
Got myself a pretty beat Firepower 3 weeks age and been busy shotguning the boards since.
Any idea for me to troubleshoot that?
Hmm, Following.
What has been done so far:
- changed all headers (including the 40pins)
- swapped all IDC connectors to trifurcons
- replaced all harnesses connectors+housings
- replaced ALL caps on all boards
- Installed mosfets instead of TIP/ceramic resistors on the driver board
- reflowed all suspect joints
- installed Inkochnito bridge board
- installed barakandl NVram + Special Solenoid Saver board
- Replaced the 100V diodes by 91V on the Power board + some others following vid1900 bulletproofing guide
Solenoids, lamps, sounds, speech, are all working flawlessly.
Player 1-2-3-4 displays are all working flawlessly.
Everything looks good on the Master Display board.
Match window = Strobe 15 and 16,
so I've followed the wires from the display up to IC6 on the MPU but no signs of broken wires/trace. I have continuity.
Two other things thing I can report:
- in the Credit window, Strobe 8, there is a little flickering when on 1 (but not with the others numbers)
- I still have original ROMs sockets. So maybe Scanbe. Although wiggling the chips in game doesn't cause any issue.
Match stuck:
Check function 26 is set to 01
Quoted from zacaj:It's stuck on 02 even in display test?
Good question, will recheck tonight
Quoted from PINTEC:Match stuck:
It is set to 01
Ok it's official: I am completely dumb!! The left windows of the Master display actually shows... the Credits.
So I guess I simply have 2 credits here. The game was set to Free Play so I thought this was supposed to remain at 0 but I was forgetting about the credits earned in game... What a brain fart.
Will recheck everything tonight.
(still got to figure out that flickering number 1 in the Ball in Play window though)
Capture2 (resized).PNGMatch is off Set function 26 to 00 to enable
Credit window freezes when function 18 is set to 00 Freeplay the 02 could be changed to 00 by disabling freeplay and draining remaining credits followed by returning freeplay setting.
Quoted from PINTEC:Match is off Set function 26 to 00 to enable
Roger that. Will change it and see.
Thanks a lot PINTEC !
This page was printed from https://pinside.com/pinball/forum/topic/firepower-match-stuck-to-02 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
