On the bench with no driver board and running Leon's Test chip. LEDs blink ten times then stop. New U1 socket, crystal, crystal caps, and 3 different 6802/6808 chips. Verified good socket at U17.
What should a logic probe show on U1 pins (clock pins) 38 and 39 ? According to the repair guide I have, they should be pulsing. I get a steady low even though the crystal and it's caps are new. I get the same result with 3 different CPU chips. I don't get a clock pulse even when the LEDs flash before stopping.
What would cause no clock signal? Any other suggestions? Reset stays low then goes high like it should.
Jason
