Hey folks, trying to troubleshoot why row 7 lamp matrix on my firepower are not lighting in attract or game play. If I ground tab on Q61 in diagnostic mode the only ones in the row that light are "Ball in Play" and "Same Player shoots again" I've looked at all the under playfield wires and haven't seen any loose/broken wires in the chain. I also replaced Q61 and Q60 transistors with no luck. Also while I had board out, reflowed solder on pins for the connector 2J7. Not sure what to try next troubleshooting the issue.
