Williams Firepower having a problem(s). The right inner lane, right outer lane, 3 of the top 4 lanes and the 3 "power targets" on right side mid-playfield are not activating when rolled over/hit. Two original boards (see diagram), the CPU & Driver boards were replaced with a new Rottendog board (see photo) which has been in the machine for almost a year, working flawlessly until now. It was installed for me by a competent tech. Dip switches are all in the proper setting. The switches that are not functioning are # 01, 03, 04, 05, 09, 26, 28, 29, 30, 31, 34 and 39.
I re-seated both connectors on right side of Rottendog board & tested. Still has same issues. Any suggestions or ideas of what is causing the problem & potential fixes? Thank you.
