So I have a sort of strange issue with my Firepower pin.
I picked it up a few years back non-working. I rebuilt the driver board using Vid’s guide and replaced the MPU with a rebuilt one.
Everything was working until it wasn’t. The upper right jet bumper coil would lock on when starting a game. It would also lock in test mode. Same behavior when I disconnected J13 from the board.
I traced it back to the transistors and chips associated with the coil, replacing the suspect parts but it still never worked. I also installed a solenoid fuse saver board board (https://pinside.com/pinball/forum/topic/special-solenoid-saver-board-for-wms-3-7) to prevent any further damage to the boards.
I decided to replace the original MPU and driver boards with Kohout MPU and driver boards. With the Kohout boards in place the upper jet bumper works, however the right sling now locks on. Same behavior as the upper right jet bumper when using the original boards. It also locks in test mode; both with or without J13 connected. I would imagine if there was a playfield switch issue, the same error would occur with either set of boards.
Should I be looking for an issue on the board or a short with the playfield wiring? I know it’s always possible but I find it unlikely that there is an issue with the Kohout boards.
Thanks,
Robert
