Hello to all. Just acquired Firepower II and working out the gremlins. Players 1 and 3 first digit is out, but my bigger concern right now is that all displays strobe from left to right. I will post a video link later, but it you imagine in attract mode the displays might strobe from left to right over and over. Even coin and player displays do this. Not sure if it is supposed to. But once you start a game I woukd think the displays should go solid, but they continue to strobe at all times. You can read the scores but it is annoying. It is not like a loose connection or a flickering, they all light up bright and fade left to right in unison. The machine does have a Rottendog CPU/driver board. Could this be programmed this way intentionally? It just seems too uniform motion to be a failing component, but my experience with solid state games is in its infancy.
Any tips / insight would be most appreciated.
