(Topic ID: 249256)
Firepower - Displays start on 222222
By RXTbone
  • 12 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by RXTbone
    #1 4 years ago
    Game functioned properly for a period of time - now it's sits off for several months, then someone fires it up to play a game... Batteries are fresh. Upon startup, players 1 and 2 display 000000, and function properly during game play. Player 3 and 4 will start at 222222. Game play will change the numbers, but none of them are right.
    Of note: First issue with display 3 and 4 was that they originally displayed 333333. I cleaned the door/diagnostics connector on the MPU board servicing another issue with the door - and displays 3 and 4 went from 333333 from 222222.
    Any suggestion for where to start trouble shooting would be appreciated.
    #2 4 years ago
    put the game in display test and see what the count is and if numbers are certain displays are skipped and others repeated.
    I think you are going to have a connector issue at the MPU on 9 pin plugs across the top of the MPU.
    #3 4 years ago
    Any ideas why re-seating the door/diagnostics plug would switch the 3d and 4th player from 333333 to 222222?
    #4 4 years ago
    Quoted from RXTbone:
    because that plug is nearby the display digit count encoded data plugs and it made the board flex breaking/opening an intermittent connection. Probably broken solder joints on the connector pins. Take a picture of the back of the MPU board and we can probably see the bad solder.
    There is 4 bits from the MPU that get decoded by a 4543 chip to form a number. Here is the display decoder chip truth table. Note how bit B can change all zeros (what it should be) to all 2's. If B and A are wrong all zeros can turn to all 3's
    Check this connector with the orange arrow pointing at it. Probably where the issue is.
    #5 4 years ago
    Thank you for taking the time to provide such detailed info. I will check this out and follow-up. Thanks again!
    #6 4 years ago
    I tested the posts and solder joints this evening, and everything tested out OK. I did unplug the master display connection and the displays all went to 000000. Plugged it back in and 3 and 4 went to 222222 - then actually changed to 333333 before my eyes, untouched. Is this a chip fault somewhere?
    #7 4 years ago
    Suggest Re seating the cables on the Master Display Board.
    #8 4 years ago
    Thank you for the help - already did a swap, between 2 and 3. Player 2 went to 333333, and 3 zeroed out. I think this is back to a chip identified as IC18/6820. But - this is beyond my testing abilities or knowledge.
    #9 4 years ago
    Good chance PIA is functions as its able to produce correct output at player 1 and player 2 displays good segment data, further distribution of signals is done on the Master display board after IC 6 which could be partially working and not throwing correct strobe timing at P3 and P4
    Before changing the PIA IC 18 or decoder IC 6 or Master display, the signals need to be checked for full presence at IJ5 , IJ6 and, IJ7 and if a signal(s) is missing will need to be traced to the source by isolation using a logic probe.
    #10 4 years ago
    Thank you for the reply! Is the forum allowed to recommend someone to work on boards? Been several years since I had board work done. Thanks!
    #11 4 years ago
    Chris Hibler is a well known tech here that can service your boards - http://chrishiblerpinball.com/.
    I've also used the Coin-Op Cauldron numerous times and they've always done good work. Good luck!
    #12 4 years ago
    Awesome - thanks for everyone's help! Always appreciate a responsive helpful forum.
    This page was printed from https://pinside.com/pinball/forum/topic/firepower-displays-start-on-222222 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
