Hi guys, looking for some experienced opinions on this. My displays are getting bad digit information. The player 1 and 2 displays (in the 2nd,4th and 6th digits position is EITHER a "0" or a "1." The player 3 and 4 displays have the same problem, except those digits are alternating "1" and "2." And the match/credit display follows the 3/4 player problem.
Here's a link to a video of whats happening...
Here's what I know: The master display board is NOT the problem because I've tried it in another Firepower machine.
I have continuity on all connectors and cables from the MPU to the display boards
I am getting PULSING with the logic probe on all data lines starting at the PIA, all the way down to the
connectors at the Master Display board.
I've replaced the IC18 PIA and the encoder IC just to eliminate them as the problem, but no such luck.
Clay's guide mentions PIAs on the driver board causing missing digit problems on the displays, so I swapped those
out as well, but no change.
Anyone have a clue whats going on?
TAGS System 6 williams firepower display
