(Topic ID: 246524)
Firepower display issue
By EMsInKC
7 months ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 7 months ago by EMsInKC
    #1 7 months ago
    I am mostly helpless on Williams SS games but willing to learn. Two issues.
    1. Player 2 1 pt display should always show 0. Always shows 8. I switched connectors and the problem followed the connector. I assume transistors control this? Where should I start?
    2. Credits are fine until you go over 9. Then they jump to 80. From 80 when you start another game it drops back to 09.
    Any help greatly appreciated
    #2 7 months ago
    Turn it off.
    Pull one of/the battery/batteries.
    Wait 30 seconds.
    Reinstall Battery/ies.
    Power up. It should come up with the "04" code displayed.
    Leave coin door open and cycle power twice. Off-On...Off-On.
    See if anything changed.
    You'll have to reset any non-factory settings.
    #3 7 months ago
    Go into diagnostics and run the display test to verify problem segments. See if adjusting the top-second-from-right connector on CPU board affects segments. That's a likely culprit that often needs a new connector and/or resoldered pins. Also can see if reseating master display connectors has any effects.
    #4 7 months ago
    I've run the diagnostics for the displays and all functioned normally. I'll try the other suggestions tomorrow and report back. Thanks guys.
    #5 7 months ago
    On diagnostics everything was correct. Today I played a 4 player game and the 8 changed to 0. After I shut it off and turned it back on the 8 returned. Weird.
    $ 8.50
    $ 74.00
    Id Rather Play Pinball
    $ 149.00
    $ 14.95
    COINTAKER.COM
    $ 34.95
    $ 229.99
    $ 799.00
    $ 104.00
    nvram.weebly.com
    $ 5,899.00
    Gulf Coast Pinball, LLC
    $ 4.49
    $ 90.00
    Lighting - Under Cabinet
    $ 19.95
    € 95.00
    FlipperLED
    € 60.00
    Buthamburg
    $ 48.00
    $ 120.00
    G-Money Mods
    $ 7,599.00
    Little Shop Of Games
    $ 16.00
    $ 209.99
    $ 149.00
    $ 279.95
    Pin Stadium Pinball LEDs
    $ 149.00
    $ 60.00
    Mods for your pinballs
