I’m new to working on pinball
Machines, so be nice please.
I have a new to me firepower. When I got it it had a blown fuse and several problems with the trough switches. I got it to start and it worked well except the flippers are weak so I ordered rebuild kits and the left side ball save only successfully saved a drain less than half the time.
I ordered parts for the flipper rebuilds and figured I’d adjust the left ball save and switch the coil with the one from the knocker for free games (seems this one would get a lot less use). When I made the swap, I took pictures and wired each coil the same way as it was.
The next time I started the game, the left eject hole, right eject hole, and the ball ramp thrower were all powered on continuously as soon as I hit the switch. They stay powered and get hot if I don’t turn it back off. I’ve looked for ground outs and don’t see any. Is there a logical direction to head from here?
Thank you in advance.
