Quoted from SchertzPinball:All the coils fire simultaneously the instant the game comes on. TP4 should be at zero after the board boots, but it stays at 5v. It is my understanding that if the blanking circuit was working properly, TP4 would be at 0v after it booted up.
Jason
Figure out if blanking is logic low during the power on reset. I suspect your blanking is fine. 90% of the time blanking is a SYMPTOM of a non working board, not a cause.
Blanking is a safety check. It monitors a display PIA line for activity. If there is no activity, blanking goes LOW to turn off all lamps, solenoids and display. When the blanking is HIGH, the solenoids, lamps, etc can work because the blanking completes an AND gate, typically via 7408, to enable solenoids etc.
Locked high blanking wouldnt stop the displays from working. It might make the display lock on scrambled stuff during reset tho.
