(Topic ID: 326326)
Firepower 2 flipper not firing
By sparrowsinfrost
1 year ago
#1 1 year ago
20221124_110245 (resized).jpg20221124_110245 (resized).jpgThe right flipper on my firepower stopped working, it also controlls the lane change. there is no spark when the switch engages. looking at the capacitor leg it looks a little toasty, is there a good way to test this capacitor without desodering? also does anyone know where I can get a capacitor that will replace this if it is in fact the capacitor. Thanks for any advice
Screenshot_20221124-115150_Gallery (resized).jpgScreenshot_20221124-115150_Gallery (resized).jpg
#2 1 year ago
Not sure why you have a capacitor on the flipper circuit. I'd remove it, but don't think that's your problem. You have power to the solenoid?
#3 1 year ago
Quoted from JethroP:
From what I gather the capacitor reduces the arc on the contact with the leaf switch to reduce degradation, the other switch also has one, the solenoid has power, and the left flipper works so it isn't a fuse. with the playfield lifted I can see a spark when the leaf switch makes contact on the left flipper and no spark on the right
#4 1 year ago
Capacitors can fail in a variety of ways, but the only way I can see that would cause the switch to just not work at all is for the capacitor to short. You can test that very easily while it's still soldered in. There shouldn't be continuity between the legs. If your multimeter has a capacitance setting, you can also test that; it may be less accurate while the capacitor is soldered in, but you should get something reasonably close I think.
The main discoloration I see in your photo is on one leg, and that looks like it's just flux that dripped down from the solder joint.
I can't see anything readable in the photo that would tell what capacitance that component is. It's obviously rated for 200 V, but if there were standard markings on it, they've worn off. Maybe there was a different marking scheme used when it was made and the "T 1" or "1 Z" are meaningful to someone with better knowledge. Of course, you could just pull the capacitor from the left flipper and measure it.
Note that if the capacitor shorted, it might have (probably) caused the flipper to get stuck, then eventually burn something else out. So you'll want to trace back and check the other components involved, such as the driver transistor, and resistors or diodes, if any (if you can't tell, I don't actually know the boards in this game specifically, so I can only write in general terms).
#5 1 year ago
Quoted from pete_d:
good place to start, should measure at leat close
Quoted from pete_d:
wouldn't it have blown the fuse though? the flippers on this machine share a slow blowfuses, inspected and looks fine.
#6 1 year ago
Quoted from sparrowsinfrost:
I don't know. Depending on the overcurrent condition, you might toast a transistor before the fuse blows. Besides, a shorted capacitor isn't going to put the load over the limit for the fuse, since it's just like closing the switch. So maybe the transistor or other component would still have a chance to overheat.
I'm not an expert in this area. I just know the circuits aren't all that complicated, so I usually just start at the point of failure, and work my way back until I find something that's amiss. You can start with the capacitor. You could even just take it out of the circuit; as noted above, the flipper should still work fine without it, you'll just get a stronger arc on the switches points.
Without the capacitor in the circuit, that frees you up to look at other stuff without worrying that the capacitor is interfering with your testing.
#7 1 year ago
Quoted from pete_d:
good point, completing the circuit should fire the flipper if it fires its in the switch, if not time to start tracing.
#8 1 year ago
Found some really questionable re-welds around the flipper coil,cleaned and resodered joints, working 100% thanks to all responses!!!
Tools
Pincoder Store
$ 3.00
Tools
Nezzy's Pinball Prints
$ 36.95
$ 22.50
2,200 (Firm)
Shrewsbury, MA
$ 1.00
Pinball Alley
arcade-cabinets.com
$ 12.50
RoyGBev Pinball
$ 11.95
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/firepower-2-flipper-not-firing and we tried optimising it for printing. Some page elements may have been deliberately hidden.
