New! Dark mode!
(Topic ID: 223278)
Fireball ii Sound and Demon Post Issues.
By dpapclare
2 years ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by dpapclare
#1 2 years ago
I picked up a Fireball ii on Monday and it is in beautiful condition, but there are a few minor issues I can't quite seem to figure out. One of the issues is regarding the sound and the other is regarding the Little Demon Post.
Sound Issues: So all of the sounds are there and working, but some of them are excessively loud compared to others. Background tones, drop target/ stand-up target sounds and some other sounds are all at a relatively normal level, but then the pop bumper effects, slingshot effects, multi-ball start sound effect and the bonus collect sound are extremely loud. I have adjusted the volume from both knobs (on the squak and talk board and on the coin door.) All of the sound effects go up and down in volume using both knobs, but those specific few sound effects are just so much louder than the rest of them. This means I can't keep the volume up for the background tone etc because the pop bumper and other affected sound effects become excessively loud. I was thinking maybe some of the capacitors were drying out on the sound board but I don't know if that makes any sense.
Little Demon Post Issue: This one is far more simple. Sometimes the little demon post just fires on its own without hitting the button. I checked the gaps on the cabinet switch for it and it seems okay. It's kind of acting up like some pop bumpers do on these older bally's, where they fire when the flippers are pressed. This is annoying because it uses up the demon credits you need to help keep the ball in play and by the time you actually need them, they can all be gone. So any input as to what may be causing that would be greatly appreciated.
Thanks in advance for looking and any advice you give me!
#2 2 years ago
My FB II does the same thing w/the "Little Demon"post. It will fire by itself sometimes, usually w/other solenoid activity. I relate it to the phantom random bumpers firing sometimes on most of my old Bally games. It doesn't happen often, but enough that I notice. The sound thing I have no idea. Good luck, that's a good looking game!!
#3 2 years ago
Quoted from pinkid:
The sound board actually regulates its volume after the game has been on for 10 minutes or so! So I am assuming the board just takes a while to do whatever it needs to do after the startup sequence is finished. I'll look into some common causes of the phantom pops online. Thanks for the info!
#4 2 years ago
Has the soundboard had it's capacitors replaced ever?
#5 2 years ago
Quoted from pinkid:
As far as I know it has not. That is what I am assuming is causing the problem. Once the machone has been on for ten minutes or so, the sound regulates itself.
#6 2 years ago
There are 2 different sound chips and circuits used on the S&T board each with it's own subset of sounds. Some games use 1 or the other or both and I'm not sure if FBII used both but if it did, one of the op amp circuits could have a bad cap that would only affect just some sounds.
#7 2 years ago
Quoted from BigAl56:
That's great information thank you! I'll look into it.
$ 149.00
nvram.weebly.com
Third Coast Pinball
1,950 (Firm)
Peabody, MA
$ 149.95
Allteksystems
$ 49.99
PinballElectronics.com
$ 119.95
Allteksystems
$ 9.00
Displays
PinballSolutions.eu
$ 999.00
$ 4.49
$ 11.95
$ 24.75
The MOD Couple
