(Topic ID: 224438)
Fireball II captive ball question
By jlbintn
  • 20 posts
  • 6 Pinsiders participating
  • Latest reply 71 days ago by jlbintn
#1 4 years ago
Recently completed a playfield swap on this game. The game is operational and playable.
My question involves the captive ball feature in the middle of the playfield. Mine does not sling the ball back and forth as I have seen and been told it is supposed to do.
It moves the ball, but the movement of the captive ball seems "weak". When activated during game play, the ball moves upwards but likes to hang out over the button, never really moving up towards the top to be bounced back down over the button.
Is this just a weakness in an old coil? I am looking for some place to start in order to get this functioning the way I believe it should work. I hope that this is the correct forum to start this topic.
I am through the playfield swap and am now on to tuning the game up. New diodes on all switches, except captive ball. The original playfield and the junk playfield I bought for a template and spare parts did not have a diode on this particular switch. Coils are what came off of the original playfield and are functioning. All connectors have been redone in the backbox, with a few to go in the cabinet.
Any help is greatly appreciated. Thanks in advance.
I am running a Callahan MPU, an Alltek Lamp Driver and SDB, and the original Squawk & Talk (with a pot and cap rebuild done).
#2 4 years ago
The switch in the center of the captive ball trough is tricky to adjust perfectly. If the gap is too small it will just hover around the center. You need to adjust the tension on the switch so that it has maximum travel before opening.
This is going from memory on a Fireball II that I owned many years ago.
#3 4 years ago
Quoted from KC_Masterpiece:
Thank you very very much.
eta
That worked.
#4 4 years ago
I recently purchased my first pinball, Fireball II, and I am having the same issue. This is my first pin so I am new to all this. I've tried to adust the switch with not much success. Any help or pics would be much appreciated . Thanks for your help
#5 4 years ago
I just finished restoring one and that switch needs to be cleaned good and adjusted just right. But even after doing that I still replaced the magnet and that made a big difference in the speed.
#6 4 years ago
Thanks gmkalos, here is a pic of the switch in question, just cant seem to get it right. I was able to make it activate but it acts like it just engages the magnet, it grabs the ball but thats it. Any help much appreciated. Ive noticed parts for these are very limited, where do you shop your parts?
#7 4 years ago
Here's mine. Switch is normally closed. Works perfectly. The small pin at the bottom of the magnet needs to be held in by the top leaf of the switch. The rest of the switch leaves then align straight with the top leaf with the switch contacts closed.
#8 4 years ago
Quoted from ODENONMYSIDE513:
Yes your double stacked leaf switch is way of of wack, look at Shock_Me's switch it needs to sit parallel. I would remove it and straighten the leafs out, re install it and make adjustments. You can pick up a new one and magnet from MARCO pinball parts. But your switch is fine I think you may be missing that little e-clip for the stem, check out these pics I made for you.
#9 4 years ago
Thanks for all the pics and tips guys, haven't had a chance to mess with it yet, but hopefully tomorrow I will be racking up fireball bonuses!
#10 4 years ago
Success! I must say that pinside is the greatest! Thanks to you guys the fireball bonus is up and running, made an amazing game ever better, can't thank you enough. Being new to this it's nice that you can find people to share their wealth of knowledge, thanks again you guys, my wife and I truly appreciate it, Fireball II has turned her into a pinball junkie and I couldn't be happier!
#11 4 years ago
Why on earth was the ancient 'Doodlebug' doing on a Fireball themed pinball anyway??
Norm Clark invented this feature back in the 1960s and despite protests from the game team at Bally, insisted it be included on Fireball II.
Some of us asked if it there was a way to capture the pinball and insert it into the Doodlebug, now that would be cool.
But no, Norm C insisted we just put the DB into the game as-is.
To quote my cousin Vinny, "You was serious about that?"
4 years later
#12 3 months ago
Does anybody know of, or if it exists, a suitable magnet coil replacement for the Fireball Unit, part number E-184-283?
#13 3 months ago
Been a while but I think its equivalent to the Williams MagneSave coil.
#14 89 days ago
Is there any effective way to test these things? Other than building a new switch, which I'm going to do eventually, I think I have the switch as good as I can get it. I don't want to keep tweaking. I'm pretty sure a new magnet coil is the answer.
#15 89 days ago
Its powered as any other coil. Should be 43v on one side of the coil and grounding the other side will make it fire. More likely the relay board that drives it is the problem.
#16 88 days ago
Relay board?
The little Fireball Unit coil checks out fine voltage wise, and fires when I ground one lug. I'm not sure what you are referring to.
edit to add:
Coil I've got installed: G-36-6900.
#17 87 days ago
To paraphrase Obi-wan: This is not the coil I was looking for.
FO-36-7000 was the coil on the relay. Trying to remember back to the playfield swap and why I didn't put the original coil on. Dug through my spare parts and found the original coil, GO-36-6900. Put it on and the ball moves as it should.
Thanks BigAl56
#18 75 days ago
Ran into an issue last night, where the ball doesn't move as the bonus counts down. I ran the game through test mode, the coil didn't fire. I manually worked the actuator, and it moved freely. Put the playfield down and it "corrected". Prior to this happening, I had played several games in a row to test the machine with the new rubber rings I had just put on. I needed to make a few minor switch adjustments, but nothing major. At any rate, it seemed to correct itself, and functioned properly after I tested and looked at it. I played a couple of games about an hour ago and it worked fine. Does anybody know the resistance on that coil? It's the original, GO-36-6900. I have a G-36-6900 sitting in storage that I just got from PBR. I cleaned up the old coil and put a new diode on before installing. The switch on the doodlebug is as tight as I can get it, although I did notice the fish paper lays on top of the top contact leaf, instead of "floating" in the middle.
Any thoughts?
edit to add
I'm running all Alltek boards. Only stock board left in the game is the S&T, and the two little boards mounted underneath the playfield.
#19 72 days ago
Probably a loose wire. I would check the coil wires. They are very fine and can easily break away.
#20 71 days ago
Thanks. Checked the wiring, it's all fine. Isolated the problem to the switch. It's intermittent, and if I understand coils properly, they either work or they don't work. The coil itself looks fine. I don't think it has ever been heated to excess, there are no indications that it has been at any rate.
I ran the game through the solenoid test. Every time I put my finger on the bottom of the switch, barely applying pressure, the coil fired. If I left it untouched, the coil wouldn't fire. The contacts are touching, by visual inspection. The switch looks perfect, but apparently it's not. Vibration.... or whatever, is causing the game to see the switch as open, intermittently. It might be the contacts on the switch. I bent the bottom leaf ever so slightly and the game has functioned fine since not long after I posted the problem.
I have all of the parts needed to rebuild the switch. I have done contacts, but never the lifters.
$ 5.95
The Pinball Scientist
Protection
$ 12.00
Lighting
Yoppsicle
Lighting
$ 18.95
£ 38.00
Displays
Retro Electro Designs
Displays
Displays
PinballSolutions.eu
Displays
Men
$ 199.95
£ 180.00
Displays
Displays
$ 149.95
Allteksystems
$ 18.95
Displays
PinballSolutions.eu
Displays
This page was printed from https://pinside.com/pinball/forum/topic/fireball-ii-captive-ball-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
