(Topic ID: 134419)
Fireball 2 lights?
By Hazoff
8 years ago
  • 13 posts
  • 6 Pinsiders participating
  • Latest reply 5 years ago by shock_me
#1 8 years ago
Hi, wanted to see what you guys think might be the issue with both the GI and inserts on my FB 2 flickering. Seems like a power issue but I have no idea, heres a quick video. It was happening when I bought it and I know the attract and multiball has blinking GI but this is constant during gameplay. Its really not that bad and doesn't affect gameplay but I like everything 100% so any advice is appreciated.
Mike
#2 8 years ago
Your video is set to private.
#3 8 years ago
Thank you
#4 8 years ago
that looks like a LED in the GI. might be worth trying with a 555 lamp. Doesn't look flickery to me in the vid though?
#5 8 years ago
Both LED and Incand flicker, I have the board installed for LED's so that can't be it, I would say shimmering is a better word for what its doing.
3 years later
#6 5 years ago
Bringing this topic back to life. My Fireball ii also has a flicker in the GI with an alltek led board in it and set up to run led's. My inserts and bckglass lights do not flicker, only the GI. Any ideas?
#7 5 years ago
The lamp flasher and/or a solenoid expander board used in Bally games requires a standard 555 lamp to operate. Look under the playfield for a lamp socket near the flasher board that does not appear to do anything. Make sure it has a working 555 bulb in it and has not been replaced by a LED.
#8 5 years ago
Quoted from BigAl56:
Okay, I installed a working incandescent 555 bulb in the socket. I turned the machine on and I am still getting the flickering from the GI.
#9 5 years ago
I believe that game has both a lamp driver and flasher. Are there 2 small boards under the playfield each with a dummy 555 lamp?
1 month later
#10 5 years ago
Yes there is! I found the second dummy 555 lamp socket and it was not working. I just ordered a new socket. Will let you know what happens after it is replaced.
3 weeks later
#11 5 years ago
Still waiting on the socket to come in, but it seems to have developed another issue. All of the GI and feature lamps are barely working now. The light driver boards are the new ALLTEK led ones and are grounded properly. Everything else seems to be getting power (displays, sound, playfield coils etc) so I am assuming it might be a bridge rectifier going on the rectifier board. I ordered a new one since I was planning on replacing it anyway, but if that doesn't fix it, what other issues could be causing this to happen?
#12 5 years ago
#13 5 years ago
Quoted from dpapclare:
Did you re-pin the connectors on the rectifier board? That completely solved the dim GI on my FBII.
$ 22.95
2,600 (OBO)
Freeland, MD
Third Coast Pinball
£ 195.00
$ 90.00
$ 18.95
2,600
Collegeville, PA
$ 18.00
This page was printed from https://pinside.com/pinball/forum/topic/fireball-2-lights and we tried optimising it for printing. Some page elements may have been deliberately hidden.
