(Topic ID: 219317)
Fire power sound board issues any advice?
By Eddie
5 years ago
#1 5 years ago
OK Im still working on a Firepower and there is one issue left, the sound.
First there was no sound so I did all of the basic steps
Desoldered and reflowed all of the Headers and any suspicious pins
Cleaned off prior poorly done rework.
All new caps, fuse holders and fuses installed
All socketed chips cleaned of gunk all sockets cleaned
All connectors inspected cleaned and tested
This was done to both sound and speech boards and ALL traces were tested for continuity.
Test point voltages are perfect.
Boards were than cleaned.
Once that was done I had sound.
Sound in Test is perfect both speech and background.
The issue is that the sound would loose half of what I am guessing is its signal or part of it during gameplay.
On occasion it would work perfectly but mostly sounds(Background) sounds not speech would drop out and on occasion when the game ends an unusual background sound would continue until the machine was turned off and then on again.
I noticed that the amp and the heatsink were loose and when, on occasion, all sound would go out and I moved the heatsink by hand it would return or fluctuate while moving it, from nothing to very loud. but with the same issues
I saw that there was prior work done on the amp so I just decided to replace it and rework /clean up the area and use new thermal paste as the old had turned to useless powder. the heatsink and amp were then solid and not loose and flopping.
Now the sound never fails completely but the other issues remain (Background sound dropping out and sometimes sound remaining when game is over) I am guessing it is one of 3 chips, if so, is this a typical issue and could someone tell me which may be the culprit? It would save me time shotgunning them thanks.
#2 5 years ago
If you haven't replaced the OEM sockets and the originals were ScanBe, they need to be your next step.
After that, make sure power is correct at the TPs,
Test the socketed chips (processor, 6821, RAM),
Replace the ROM on the sound board half.
Carry on soldier.
Chris Hibler - CARGPB #31
http://www.ChrisHiblerPinball.com/Contact
#3 5 years ago
Clean and reseat the ribbon cable between the sound and voice card. The "sound" signal goes to the voice card for mixing with the voice signal before coming back to the sound card to be amplified. Could be the sound signal is getting dropped. - long shot
My money is on ROM sockets as Chis said. I wouldn't only suggest Scanbe. Any socket where the chip inserts or removes too easily, needs to be replaced. I've seen non-scanbe sockets that couldn't overcome gravity to hold a chip in the socket.
#4 5 years ago
I've seen cracked solder connections on the driver bd and or flaky connectors cause this issue as well.
2,900 (OBO)
Hawesville, KY
1,400 (Firm)
Benton, PA
$ 42.95
Tools
Pincoder Store
$ 170.00
Displays
Digipinball Shop
Playfield - Plastics
The Pinball Scientist
Trade
Machine - For Trade
Washington Court House, OH
600 (OBO)
Casper, WY
$ 27.95
This page was printed from https://pinside.com/pinball/forum/topic/fire-power-sound-board-issues-any-advice and we tried optimising it for printing. Some page elements may have been deliberately hidden.
