(Topic ID: 341412)
Fire Power lane advance
By Dancoar
3 months ago
  • 17 posts
  • 5 Pinsiders participating
  • Latest reply 89 days ago by Dancoar
#1 3 months ago
So I recently acquired a fire power. It good working order, but recently the lane advance for FIRE, which would work by pressing the right flipper button stopped working.
I determined that the problem was at the flipper assembly. By trial and error I adjusted the outer leaf on what I think is the EOS switch and it worked beautifully.
However, now every time I hit the flipper button, the onus advances as if I had gone down an open lane.
ie from 1-2-3etc not the 2x-3x
Where have I gone wrong?
#2 3 months ago
Without hitting the flipper button, pound on the playfield to see if the bonus advances. If it does, then you have a switch that is closing due to vibration. Check all the switches that advance the bonus for contacts too close together. The EOS or switches on the flipper button should not cause what you are describing.
#3 3 months ago
Suspect shorted lane change to EOS switch stack:
Place game into switch test press flipper note switch(s) #'s
#4 3 months ago
Went through the switch test and none were up. Shook the playfield and did not advance bonus.
Played with the switch at the flipper, picture included.
The outside leaf marked by yellow when pressed into the next leaf advances the lane change and the bonus.
If adjusted so that when the flipper is engaged the leafs touch, both the lane changes and the bonus advances
I should also say that I am not experienced with doing this, but excited to get more involved
Thanks for your help
#5 3 months ago
While in switch test with all balls out of the machine, make the EOS and see what switch(Es) come up
#6 3 months ago
the negative side of the diode leg looks like it's touching the solder tab with the blue/green wire?
#7 3 months ago
The next step is to
Place game back in switch test, Actuating the Lange change switch will show #45 on the display
No?
Suspect Flipper EOS voltage short into Lange change switch stack to the driverboard switch circuit
Keep game in switch test next check all other remaining 13 switches in Column #6 and Row #5 #61 is not used
Note switch #'s
#8 3 months ago
The outer switch doesn't look like the right switch. The large high power contacts are for EOS switches, not low power switch matrix switches. Also, both blades are bent noticeably, which likely causes the contacts to not to be flush when closed. You can find the correct part number in the parts book linked below.
https://www.planetarypinball.com/williamsbally-parts-manuals
In the mean time, try lightly sanding the contacts on the incorrect switch. High power contacts often have oxidation you can't see, causing resistance. Switch should measure less than 1 ohm resistance when closed. Sanding the contacts may get it working until the correct switch arrives.
#9 3 months ago
Appreciate all the help and insight.
Easiest first: I checked to be sure there were no wires touching where they shouldn’t and the diode leg was clear.
I went back to the switch test and activated the right flipper, #45. Unfortunately at some point, the entire flipper stopped firing. I took the entire assembly out, lightly sanded the contact points and established appropriate position for the leafs. I did get the flipper working appropriately… but still do not have lane advance.
That was enough adventure for tonite. I plan to check the switches for the column and row tomarrow.
#10 3 months ago
Update. First and foremost, I am incompetent.
Understanding that. I did a complete switch test.
At start up, none were shown as closed.
I tested each as best I could.
Coin door and # 4,5,6. Were non functional.
Slam tilt #7 and play field tilt #47 also did not work.
I could not identify #51,57, 58 (ball ramps) do not sure what they are doing. #45 was out as was #37.
I also blew the flipper fuse. It had been ok, but I goofed up something. I replaced the fuse with a 3amp fuse but it blew when I hit the right flipper button. Left flipper was ok until the fuse blew.
I think that I will get a new right flipper assembly.
Any other thoughts.
Thank you all so much
Though frustrating, this is fun
#11 3 months ago
Update, I misread the fuse type.. should be 10 amps?
#12 3 months ago
yes F4 should be 10A Slow Blow
#13 3 months ago
Yes. Thanks. Not sure where I got the 3amp. But is working again. Still not getting the lane advance. Looking at switch 37 and 45
#14 3 months ago
have you confirmed continuity for the White/Green and the Green/Blue back to the driver board top right-hand side connectors?
in post #4 you say that when you 'make' the lane change switch contacts, that the lane does change, is this correct? Is this fixed now?
#15 3 months ago
Lane change does not work. All other switches work. #37 had the leafs installed backwards, but does work with good contact.
Have not checked continuity.. will try next week.
Another finding is that when target 4 is hit, targets 1-4 light up. You only get points for the one hit. All other targets act independently. Targets 1-4 switches are on the same column.
#16 3 months ago
Adventure continues. I installed a brand new right flipper complex with lane change. After adjusting EOS switch, flipper works perfectly. But still no lane change. Mechanically, the flipper does close the lane change switch. Tried checking continuity of row ( white green wire), but am a little clumsy with leads. Am getting alligator clips to help and will check later this week. Did inspect individual switches and they look intact with no loose wires. All work in switch test mode and during play.
Am afraid problem is on the driver board?
#17 89 days ago
My fire power needs more work. I did replace the right flipper assembly and now have lane advance working, but it again also advances the carry over bonus by 1000 with each hit.
I have checked continuity for column 6 and row 5.
I used the single reference point at switch 45 and had good signals to all switches in the row and up to the board connection. For the column I used #43 and was good for 41,42,44,45,48 and to the board. Could not find 47,46.
Other issues have developed.
1. When target 4 is hit, it lights up 1,2,3&4.
2. When I turn it on the upper right eject fires multiple times before stopping. I have credits and hit the start button, score resets and it says FirePower, but no balls load into the shooter.
I have checked the switch with the ejector and it is working properly. I have checked continuity for column 5 and row 4 and they are good.
I checked solenoid test in diagnostics? And 2,3,4 did not fire
Many questions:
1. Is the continuity testing valid from a single reference point.
2. Is the problem likely in the board.
3. Ideas regarding the balls not loading and repeating ejector
$ 27.95
Other
$ 42.95
Protection
$ 12.50
RoyGBev Pinball
Led
$ 649.95
Pin Stadium Pinball Mods
Led
$ 52.99
Pinball Shark
Shooter rods
$ 11.00
$ 44.99
Pinball Shark
Shooter rods
This page was printed from https://pinside.com/pinball/forum/topic/fire-power-lane-advance and we tried optimising it for printing. Some page elements may have been deliberately hidden.
