(Topic ID: 292194)
Fire! bell questions
By mjmmx
8 months ago
  • 8 posts
  • 6 Pinsiders participating
  • Latest reply 8 months ago by LTG
#1 8 months ago
I recently got a fire pinball machine. a good portion of time has been spent getting it running and i am down to a few last issues.
I was wondering anyone knew the length and threading for the plastic screw. Mine was missing and the manual has no info from what i can see about the bell assembly. also what length of plastic screw thread needs to be on the solonoid side so that the bell rings properly when the solonoid engauges?
#2 8 months ago
Doesn't really answer your questions, but (from the parts manual)...
https://online.fliphtml5.com/vrtyz/rvsk/#p=427
http://www.planetarypinball.com/mm5/merchant.mvc?Screen=BOOK
#4 8 months ago
thanks for both posts. i now i have the info i need to get a nylon screw. that is definately a great start.
#5 8 months ago
I can't think of any reason that this screw needs to be nylon. It's just an adjustable stop.
In case the coil shorts to the plunger perhaps?
#6 8 months ago
maybe the reason is that it'll be quieter if the adjustment screw is plastic vs metal?
#7 8 months ago
Quoted from yaksplat:
Perhaps just to lessen wear/noise? I agree... it probably doesn't have to be nylon. you could probably just use a metal screw with a piece of rubber (Maybe a shooter tip?) on the end to lessen wear/noise
#8 8 months ago
It doesn't have to be.
Nylon would be quieter when the plunger hits it. And the end won't peen over like a metal one, should you ever want to remove it, which would make unscrewing it hard if not impossible. And you won't wear a spot on the bottom of the plunger.
