The globes with nothing printed on them are suspect. You have no idea of the "type" of those bulbs. They could be for/from anything, automotive, boats, ect.
Now, your voltage question is a complex one... It should actually be much higher than 13.2V (more like 28V when not under load) but let's not worry about that... Sounds like you tested for "AC" volts, not "DC". No biggie.
My strong suggestion is to remove the "grounding" wire on one of those small warming boards and see if that resolves your problem. (I think it's the wire furthest to the right in your picture above). And then tape it up or add heatshink to it so it doesn't touch other stuff. If that works, remove the grounding wire on all those "warming" boards.
The grounding wire (actually the entire resistor) is not really necessary, it only makes the bulbs pulse brighter when pulled on. You could remove those large resistors but that's a lot more work.
Now, this also assumes you have the proper bulbs installed.
The technical reasoning is better explained here in this thread:
https://pinside.com/pinball/forum/topic/removing-warming-resistors
There could be pinball purists that post under this like "no, don't do that" and OMG no... blah blah, just ignore those fools.
