I guess I did not explain it very well since my ceiling was too low I couldnt fully lift the play field so I tried to balance it with one hand and piece of steel on the playfield made the scratch. It was a noob mistake i learned the hard way.
Quoted from gweempose:I'm having trouble picturing how a low ceiling would cause one of your side rails to become scratched. Fortunately, it's really easy to replace the side rails on Sterns. They just unscrew and pop right off.
I contacted stern they told me that the part is unavailable so any lead on one would be great.
Quoted from BarryBurton:I was balancing the playfield after I realized I can't fully raise it and wasn't paying attention and this awesome piece of steel is what scratched it if you must know how I did it.
Yep. Rookie mistake. Just sand down the side wall and repaint. And get higher ceilings. Haha
Quoted from BarryBurton:To be clear this is my 1st machine so the top rail that holds the glass[quoted image]
If it bugs you enough to repair/replace just take it off and take it to a power coat company local to you. Any powder coat company "should" be able to strip that and match the color. Shouldn't cost you more than $75-$100. Worst case, contact pinball refinery and ask them to help. But you'd be paying shipping now thus the local option.
Any extra shooter rubber tips handy? Slide one on the metal piece, should prevent what happened for future playfield lifts.
Quoted from Jeff_PHX_AZ:Any extra shooter rubber tips handy? Slide one on the metal piece, should prevent what happened for future playfield lifts.
That would disallow properly sliding of the playfield back into place I think.
Order these things. I have 4 of them, in case I'm working on more than one game at a time.
https://www.pinballlife.com/interior-cabinet-protector-blade-set.html
Just got my first game ever and went into it with a bang. I picked up a basically brand new GoT LE and am loving it. I have it all cleaned up and things are in good working order. I am wanting to make sure I protect the shooter lane and keep it looking pristine as long as possible. What is everyone doing? I looked at this: https://pu-parts.com/game-of-thones-shooter-lane-protector but they don't ship to the US. What has everyone done, and how are your shooter lanes holding up?
Quoted from atum:Just got my first game ever and went into it with a bang. I picked up a basically brand new GoT LE and am loving it. I have it all cleaned up and things are in good working order. I am wanting to make sure I protect the shooter lane and keep it looking pristine as long as possible. What is everyone doing? I looked at this: https://pu-parts.com/game-of-thones-shooter-lane-protector but they don't ship to the US. What has everyone done, and how are your shooter lanes holding up?
Get the cliffy's www.passionforpinball.com
He has protectors for both sides of the shooter lane and the side rail.
Quoted from IdahoRealtor:Get the cliffy's www.passionforpinball.com
Thanks! I was thinking that. So that is both the ejector piece that is next to the scoop, and the side rail protector that goes under the bubble level and down the side, correct? What do you do for the shooter grove? Mylar, protector like above, or just let it ride?
Quoted from atum:What has everyone done, and how are your shooter lanes holding up?
Don't follow my advice, I play the $%&# out of it and try not to look at shooter lane. But I do wax every other month and replace balls when needed. My shooter lane is abused with battle wounds.
Quoted from atum:Thanks! I was thinking that. So that is both the ejector piece that is next to the scoop, and the side rail protector that goes under the bubble level and down the side, correct? What do you do for the shooter grove? Mylar, protector like above, or just let it ride?
No. 3 pieces. Both sides of shooter lane and side rail. The groove doesnt need protecting.
Quoted from IdahoRealtor:No. 3 pieces. Both sides of shooter lane and side rail. The groove doesnt need protecting.
He also needs the outhole protector as well.
Wax underneath any areas you do protect with mylar first. It will make it a much easier to peel off if you ever decide to remove it.
I put Mylar down first in the shooter lane, then the cliffy’s.
I also put Mylar around all magnets, drop targets and the ball drain.
when exactly does the left orbit open up on a normal game?
I finally got around to installing the capguntrooper fix (took a couple of hours of tinkering, had to remount the diverter arm) works great though.
I also re-enabled the left orbits on the feature menu.
It's seems kind of random when both controlled gates open though. Like during winter hurry up.
Figured it was a good time to put this game back on location .
It only opens during certain features or when trying to complete some houses, if I remember correctly
Quoted from hocuslocus:when exactly does the left orbit open up on a normal game?
If a flashing red combo arrow is lit on either orbit, shooting that orbit will send it all the way around. Modes like Greyjoy and Baratheon and Martell will send the left orbit all the way around too.
Winter is coming hurry up will too.
Quoted from dmieczko:Finally joined the club today. Wow, this game is awesome!!
Ya, more and more people are learning enough of the rules to realize how great this game is. Welcome to the club. Let’s hope for a final code released with the finale coming soon.
On my LE, my sword does not ever move on the lock ramp. If I go to coil test, it fires without issue, but does not fire during gameplay. I read in another thread about checking optos. This is my first pinball, so I don't really know all about the nodes, and setup and such. When the ball goes up the lock ramp, it makes the whoosh noise, so I know that opto is registering, and the exit opto must work as well as the ball lock white shaft works properly. It always registers locks and releases appropriately, but the sword does not move.
Does anyone know anything about this, or can they point me in the right direction? TIA!
That is an odd one for sure. So the white up post works but not the sword. Does the white up post stay up long enough to let you select a mode and also hold balls for multi ball? I would say that coil got unplugged or shorted out but you mentioned it works in coil test.
My best guess at this point - That coil was turned off in the feature settings. Look for the sword coil and make sure it is on.
Quoted from 85vett:That is an odd one for sure. So the white up post works but not the sword. Does the white up post stay up long enough to let you select a mode and also hold balls for multi ball? I would say that coil got unplugged or shorted out but you mentioned it works in coil test.
Yeah the entire game works as expected. Holds for multiball, releases correctly and everything, just no sword action. I have checked through all the settings (general and GoT specific) and cannot seem to find anything about enabling or disabling that feature.
Quoted from atum:Yeah the entire game works as expected. Holds for multiball, releases correctly and everything, just no sword action. I have checked through all the settings (general and GoT specific) and cannot seem to find anything about enabling or disabling that feature.
I just played a couple game and my LE is doing the exact same thing as you posted above. Time to go in setting and look under the hood.
Newest code and my sword works fine, didn't have to make any adjustments. Maybe a code update again may work out bugs.
Well it now magically works. I was replacing the battering ram with the upgraded version and poked and prodded at some cables and connectors. I have always been on the latest software version, but now magically everything is working as expected.
Quoted from atum:Well it now magically works. I was replacing the battering ram with the upgraded version and poked and prodded at some cables and connectors. I have always been on the latest software version, but now magically everything is working as expected.
My guess is that it was the ramp switch. Perhaps you jostled the connector.
Quoted from RedPlunger:Just joined the club and the rabbit hole that is pinball. Borat high five
What LE # do you have? Rabbit hole indeed. I went from 5 EM's. To 15 total after buying my first Stern just 14 months ago. Enjoy the game with the "Boys".
Quoted from Spiderpin:What LE # do you have? Rabbit hole indeed. I went from 5 EM's. To 15 total after buying my first Stern just 14 months ago. Enjoy the game with the "Boys".
#295. Super stoked to have such a cool toy to play with my two hooligans. Good lord, 5 to 15! My wife would turn me into an unsullied if I went that deep.
Wanted to share with the group a humble brag. I now have a one of a kind GOT Premium edition. Personally signed with authentication by Kit Harrington aka Jon Snow and John Bradley aka Samwell Tarly. I have been excited to get this back and share with the group. My brother did a private signing with both of them and of course I had him bring the backing to my game!!
IMG_3142 (resized).jpgIMG_0604 (resized).jpg20190508_161327 (resized).jpgAmazing!! Would love to shake both of their hands and thank them for the best fucking show ever made.
Quoted from C_S_S:If you learn only one thing from the finale, understand this....dragons understand symbolism.
I knew it!
I'm sure this question has been asked before but I'm not going to read through that many pages. Why don't you guys include the pro in this club?
Quoted from Epistaxis:I'm sure this question has been asked before but I'm not going to read through that many pages. Why don't you guys include the pro in this club?
Since the games are so different, there’s a lot of stuff that pro owners don’t need in this thread. There is a TON about how to get these premiums and LEs dialed in that it helps keep that separate.
GOT kicks ass is the general GOT thread. This one is prem/le specific.
I often go back and forth between wanting the pro vs the prem/LE. I think prem/LE is winning out though. I like the UPF.
Quoted from f3honda4me:I often go back and forth between wanting the pro vs the prem/LE. I think prem/LE is winning out though. I like the UPF.
It's not just the upper play field, it's the VUK the better dragon kickback, better rules for shot layout. It's just all good.
GOT question how do you increase the spinner value is from just shooting over and over or the Baratheon targets just wondering thanks.
Quoted from Coolpinballdino:GOT question how do you increase the spinner value is from just shooting over and over or the Baratheon targets just wondering thanks.
Yes. About 14 sets will get it to level 4 which is basically max value. That is about 3.2 million per spin.
Once there, continued completions of the drops will increase the value, but by very small amounts.
All this resets when you drain too. Spinner is affected by the PF multiplier, but not the shot multiplier.
You’ll know the spinner value is way up there by a high pitched metal on metal audio sound effect too.
Quoted from chuckwurt:Yes. About 14 sets will get it to level 4 which is basically max value. That is about 3.2 million per spin.
Thanks chuckwurt going to try the spinner strategy tonight when I get back home.
Quoted from Coolpinballdino:Thanks chuckwurt going to try the spinner strategy tonight when I get back home.
Do Martell and when in a MB do nothing but hit drops.
Also you can check the spinner level in the instant info.
Quoted from chuckwurt:Do Martell and when in a MB do nothing but hit drops.
Cool that's what I figured just keep getting multiballs and just focus on hitting drop targets.
This page was printed from https://pinside.com/pinball/forum/topic/fire-and-bloodgame-of-thrones-premiumle-club/page/28 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
