Ok - still no luck. And now I am getting more and more pissed off. Been extremely patient, bent the switch every which way I can and no luck. You are correct, in my opinion, that the small steel ramp has a lot to do with whether or not the ball makes it to the throne. When I pushed it up some, the ball will now make the throne on the first attempt most of the time...in test mode....
The problem is that damn switch. When the ball is in the VUK, the switch should show active, unfortunately, mine is not. The switch seems to actuate just fine if I push on the lever. However, when installed in the game it won't actuate. I know this is likely an adjustment of the lever. But I can tell you I have tried every adjustment I can think of and it doesn't work. I have gotten it to where if I drop the ball down the vuk it will momentarily actuate, but the lever does not stay pushed down. In other words, with a ball in the vuk, in switch test mode, I should see the vuk switch active -I don't. It's almost as if the lever is just too short. I have been it up to try and engage on the ball, but I can't bend it any higher.
Right now when I start a game, and shoot the ball into the vuk at the start of the game, it doesn't do anything. It sits in there until it goes into ball search and then shoots it up to the throne. The good news is that it makes it to the throne consistently, the bad news is it doesn't shoot it automatically to the UPF like it should and used to. Anyone have any ideas?
