Apparently punched a hole in my MDF cabinet bottom when moving one of my pins. Hole is an oval about 1" wide and 2" long. No structural damage - everything else fine. Went straight through. Hole is a little wider inside than on the bottom. Inside of cabinet is painted black so would want repair paintable.
Obviously you can't see it, but I'd still like to repair. I was thinking of using some two part wood epoxy (the Minwax stuff) to repair. Thoughts?
