hi guys where can i find the file for the cactus canyon color display pin2dmd
https://www.colordmd.com/support_firmware_chroma.html
You can find everything at colordmd.com
Select the game you want to download the file, then follow the instructions
Quoted from Coz:https://www.colordmd.com/support_firmware_chroma.html
Puoi trovare tutto su colordmd.com
Seleziona il gioco di cui desideri scaricare il file, quindi segui le istruzioni
ok thanks but this is the rom for the display I am looking for the color file
I’m not sure exactly what you’re looking for. If you have a colordmd display these are the files to load on the colordmd unit. If you have any problems or questions I suggest you contact colordmd. Not sure if you have some other type of display- you’ll need to check to see what you have.
Quoted from gunstarhero:Do you have a ColorDMD in the game?
no I only have the display I am missing the color file
Quoted from emy760:no I only have the display I am missing the color file
Then that file is all you need. Just put it on a USB an load it onto the ColorDMD and you’re all good.
Quoted from gunstarhero:Allora quel file è tutto ciò di cui hai bisogno. Basta metterlo su una USB e caricarlo su ColorDMD e sei a posto.
Ok thanks so by loading that file I also have the color display?
Quoted from emy760:Ok thanks so by loading that file I also have the color display?
You have to purchase the colordmd display. the rom update doesnt make a standard display a color one.
Maybe this guy is a time traveler looking for the CGC color file to upgrade a standard version to high-res color
So do you have a colordmd display or the original display? maybe you can show us a picture of what you have
Quoted from snakesnsparklers:Maybe this guy is a time traveler looking for the CGC color file to upgrade a standard version to high-res color
I had the same thought when I read this.
Quoted from emy760:Guys I have Pin2DMD display
You can't update that to color. Different display, different company.
You'd need the color DMD ( actually LCD ) from https://www.colordmd.com/ and then download the file from the website for your game and install it in the color DMD.
Quoted from emy760:Pin2DMD display
PLEASE edit your thread title to include this. You can get to it by clicking EDIT on your first post.
Check VPforums, you'll have better luck there
Quoted from Haymaker:Check VPforums, you'll have better luck there
Still won't give colors on Cactus Canyon like a colordmd.com LCD.
LTG: )
Quoted from LTG:Still won't give colors on Cactus Canyon like a colordmd.com LCD.
LTG: )
pin2dmd can do some things colordmd can't but its all up to somebody actually creating the files, or you tackling the project yourself. Regardless, this doesn't need to turn into another pin2dmd vs colordmd thread, I'm just simply letting OP know, thats where they talk a lot more about pin2dmd projects. I agree though, it won't be the same as colordmd.
LTG: )
Huh, have a TOM with a pin2dmd. Color works just fine albeit it has errors. Pin2dmd is a pain to build your first one. The directions, suck. Once you work through the first it is really easy to pound a few out.
I am not a fan of the colorzation files. I don't care about paying 25 per game. It is fine. But having to reach out to someone with a multi year old thread on vpu to donate/get the files. A number of them are made by people who do not have the real machine and can have quirks. If they drop the project down the road and a new rom comes out (look at what planetary has been doing) you might have to ditch it or stick with the old rom.
Colordmd is:
easier
more likely to receive updates
colorzations are more finely polished
more expensive
This said, the op's incoherent thread tells me he has next to no business dealing with a pin2dmd.
The flag tells me English isn't l likely his first language and the first post says pin2dmd, anyone replying with ColorDMD info missed that key detail.
Agree that PIN2DMD isn't as 'turn-key' or 'plug and play' as ColorDMD... that's what you get for a partial DIY project that depends entirely on crowdsourced material... you pay accordingly. There are some great sellers of PIN2DMD out there that can make it pretty easy for you though like dzorbas up here north of the boarder, I believe there is another reliable source in the US too.
Quoted from roar:The flag tells me English isn't l likely his first language and the first post says pin2dmd, anyone replying with ColorDMD info missed that key detail.
He edited the post, so nobody missed the detail, OP didn't provide it.
Quoted from dsuperbee:He edited the post, so nobody missed the detail, OP didn't provide it.
I only read the request to edit the title of the thread, not the body, assumed (Bad on me) that the detail was always in the body.
This page was printed from https://pinside.com/pinball/forum/topic/file-color-dmd-cactus-canyon- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
