The E in Peter has gone out on my Stewie Mini PF.
Anyone else run into any issue of one of the LED's stopped working?
What was the Fix?
What was the Fix?
Find out anything on this OP/bump?
I'd try this first:
Reflow the solder to see if that might do the trick. Solder between 650 to 700 degrees with a soldering station with an adjustable temperature control (like a Weller) to not damage the board.
If that fails, anyone know if this PCB be sent to any of the 3 major board guys for repair/or where can you get the LEDs to solder it yourself (guessing a distributor could get you the parts/maybe someone else has an alternative vendor link)?
Good luck OP.
Looks to be integrated. I would try as mentioned above. Or look for lamp pcb board for mini PF.
parts numbers are listed in section 5 of your manual. pg 7 references pg 142 and 143.
I had one light (also on Peter) that was intermittent ...the light board doesn't have a parts side like most pinball boards. I just kinda winged it and heated it on the top side, which reflowed the solder and it's worked like a champ since. I probably could have F'd it up and made it worse...but I got lucky this time lol
This page was printed from https://pinside.com/pinball/forum/topic/fg-mini-pf-one-led-out and we tried optimising it for printing. Some page elements may have been deliberately hidden.
